Question about HP PSC 750 All-In-One InkJet Printer
HP 750 wont scan
24/2/09
sys there is a numeric problem, have tried all the fixes on the web - reset, dismantleing to clean inside of window, however I cannot remove the 'black shield' they mention to clean the irror. There are two black plastic parts one hoizontal one vertical, which should e removed and how? They also say to not replace it once removed, do you agree?
Mant thanks, I 've wased a day so far and need to scan some documents fast!
Also , one other 'gotcha' when reset the 750 asks to press 'start' to define the language as they roll around. Mine is a french machine with a french overlay....which is fine except they guy who did the translation for the software said ' demarrer' for start which is logical ...except there is no such label on any of the keys, and none which is obviously 'start'.
Given the on off button is top left and cancel top right, which button below is the 'start' button?
Many thanks!
    Problem Solver:
  • 9 Answers
Not sure what you mean by a "numeric problem" with the scanner but these links may help you with the menu quandary :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu04814&product=57769&dlc=en&lang=en
http://h10032.www1.hp.com/ctg/Manual/bpu02246.pdf
Posted on Mar 06, 2009
Says scanner is not connected
go to hp web side page for drivers download and look the specific drivers for the scanner under your model and extract them to your hard driver and restart your sys after back on windows go to add and remove hardware again and find your device check your scanner property's and try to scan again.if you have a choice of universal drivers pick those ok.
Oct 04, 2012 | HP Officejet 5610 All-In-One InkJet...
Cant scan
Try to scan with Preview or Image Capture apps (in your Applications folder).
If that does not work, try deleting and re-adding the printer in the print queue:
- Sys Prefs, Print & Fax
- Select the printer in question and click the minus sign at the bottom of the list
- Select the plus sign to re-add it. Look for the printer, select it and wait until the "Add" button becomes available. Click it.
If this does not work, do the same thing, only instead of the second step, right (control) click the print queue area and select Reset Printing System
Jul 12, 2010 | HP Computers & Internet
Hp 4180 will scan but won't print, error cannot find printer, tried disconnecting/connecting, remove/reinstall, no fix
I have an old computer/printer hp pavilion mx 70/hp psc 750. I cannot print documents from computer to printer. I have unplugged everything but still no luck. Have removed all printers and reset my printer as default. Any ideas?
Dec 10, 2009 | HP Photosmart 4180 All-in-One Printer
The monitor will not display DOS or Windows OS. It is integrated on Montherboard. There are no beep codes... I can see the light come on when I press the power button, the fan comes on, but nothing...
clean all the webs first... reseat the RAM ... Reset the Bios... Refer the Service or User manul for steps to the above.. then try powering on the sys.. 97% it will power on.. if it powers on first Update the BIOS of the sys.... Do well bye
Sep 20, 2009 | HP Pavilion s7310n (EN996AA) PC Desktop
My HP PSC 750 all-in-one Inkjet Printer won't scan. The window on the printer/scanner/copie says, "please select destination using "scan to"." I don't remember doing this before. I don't scan often, but I...
caroljust,
The 'scan to' is a message that the scanner is saying ' I do not know where to scan this document to, that is, what program. I suggest you turn it off and turn it on again and it may reset to the default setting, otherwise you have to go into some softwear that came with that psc 750 and work with the softwear and ask it to scan from taht hp softwear from the computer. Liam
Aug 02, 2009 | HP PSC 750 All-In-One InkJet Printer
Wont scan or copy,
I have seen other HP scanner/printers with very similar problems in our shop. On many of them it is caused by dirty scanner glass or dirty mirrors. We have a tech page with step by step cleaning that should help you. You can find it at
www.ccl-la.com I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jul 03, 2009 | HP PSC 750 All-In-One InkJet Printer
Scanning
Scanner unit has failed. It costs as much to replace it as a new printer.
Mar 05, 2009 | HP PSC 750 All-In-One InkJet Printer
My hp psc 750 all-in -one printer scanner not working
A friend of mine had a HP printer (Not a PSC 750) that he had simply plugged into his computer and was able to print properly but received the "options not set" message when he tried to scan.
The solution was to install the HP driver package for his printer.
If you are using the default Windows drivers for your printer you may need to install the HP driver package to access all of your printers functions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&custom_solutionid=rd_bpu04809&product=57769
Mar 03, 2009 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
153 people viewed this question
Seeker5211
Seeker5211
