Question about Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor
On my Dell 1701FP monitor, the color red does not display anymore
No color red displays on the monitor.
JMuskovitz
  • 135 Answers
SOURCE: about colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Posted on Feb 21, 2007
  • 23 Answers
SOURCE: Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Posted on Jul 12, 2008
scrodamoon
  • 659 Answers
SOURCE: No color red displays.
If you think that electronic repair is very difficult to learn then you have to read this article where only by using a solder gun could solve a Monitor color problem. Of course there were many tough dog cases (very difficult to find out the fault) in electronic repair but at the same time there were also many cases that can be solve by some simple ways. This G70fmb Monitor came in with no blue color problem. How do I know if the blue color was missing? Simply run a color test (that you may also download from the internet) or from a Monitor testing program generator, you could clearly see as which of the color is missing when you run the color bar test.
A missing blue color in the Monitor could cause the display to turn yellowish. Troubleshooting color problem is one of the easiest in Monitor repairing. Whether the missing color is from blue, red or green there are some areas that you need to check in order to successfully repair it. Here are some of the points that you need to check:
- A bended color pin at the VGA connector. (If pin one is bend then there would be no red color)
- A defective VGA signal cable. If the internal wires were broken then there would be missing colors. You can check if the signal cable is good or bad by doing a continuity test using a multimeter.
- Dry joints in the CRT board such as in the CRT socket pins, video pre amp and driver IC and even at the connector pins. In fact this problem contributed about 80% of Monitor color problems. Applying fresh solder would usually solve the color problem.
- A defective IC either in the Video Pre-amp or Video Driver IC.
- Faulty components in the CRT board. It could be a shorted driver transistor or even electrolytic capacitors that the ESR reading had shot up!
- A bad CRT socket. Sometimes decayed glue could cause the internal pins rusted and thus affecting the colors. Replacing only the CRT socket would definitely solve the problem.
- A weak or a defective picture tube (CRT tube). Yes, I do came across one of the electron gun (most probably the cathode materials had used up) in the tube faulty caused a missing color in the screen. There’s no way to repair this type of problem-the only way is to replace the CRT tube.
- In the newer type of Monitor, color setting is save in the EEPROM IC . Thus, if the EEprom data is corrupted, you would also get a missing color! The only way to repair it is to reprogram the IC or use a soft jig to tune it back the color setting.
Now, which one of the above is the easiest to start with first when comes to troubleshooting the color problem? I believe you would agree with me that the first, second and the third are the easiest compare to the rest. Normally I would hit the Monitor with my bare hands to see if there are any changes in color at the display (be careful not to hit too hard till the casing broken). If there is a change or flashes then I can say that the Monitor has dry joints. And if it stills the same no matter how many times I hit it, I will then starts check the VGA connector and the cable.
In the above Monitor, the problem was dry joints because when I softly hit it with my hand at the side of the Monitor, the blue color immediately appears. The aluminum shielding at the CRT board was opened and I could clearly see lots of dry joints especially in the video pre amplifier and the video driver IC. When you resolder please don’t just touch on the IC’s only, you need to resolder others area as well like the CRT socket pins. Doing this would prevent any color loss again in the future. A good job would prevent call back and to save you time and money and most of all your reputation!
After everything was done, you then need to gently knock at the CRT board again with the plastic handle of the screw driver to see if the color problem still exists. You may also knock on the main board just in case there is any dry joints there. One more thing, if you find that the Monitor is a bit dusty, you may use a vacuum cleaner and a brush to clean up the dirty area.
Whether you are repairing the g70fmb or any other brand of Monitors, if you come across any monitor color problem, you can always use the procedure above to find out the fault. If the VGA signal cable is okay and there were no dry joints in the Monitor, I guess the only way is to use voltage testing method and start checking components with your tester or meter.
Posted on Aug 05, 2008
  • 50 Answers
SOURCE: monitor colors not displaying any red only blue/yellow
update the latest driver for your video card might help.
Posted on Mar 21, 2009
sys_admin
  • 829 Answers
SOURCE: Everything is displayed sideways on my monitor. how can I fix that ?
I suppose you have Nvidia Card Installed if yes then Right Click Your Desktop and select Nvidia select Standard Settings and go to Display + Rotate Display and set No Rotation . Thats it!
Posted on May 10, 2009
I have lost the original power supply for my dell 1701fp monitor. I have a power supply that I think may work as a substitute until I can replace the original. I need to know, what the acceptable voltage...
What ever you use, it must be REGULATED power supply that will maintain 14vdc output, rating at 3A. These regulated power supply can easily maintain the output voltage within +/- 5% with input AC voltage range from 100~240vac.
Linear regulator power supply may not work since it has slow response time to regulate the voltage.
http://www.amazon.com/dp/B002D1E8NE/ref=asc_df_B002D1E8NE1376531?smid=A3IZHOEADOGAP0&tag=dealtmp386264-20&linkCode=asn&creative=395105&creativeASIN=B002D1E8NE
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
My LCD monitor is blinking green but no display is coming, some days back after blinking 15-20 minute display comes. But now display not come
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 09, 2010 | Dell UltraSharp 1701FP 17" LCD Monitor
We have the same problem as snoozi reported on may 31, 2009. I see no answers or resolutions posted. Is this monitor toast?
Sorry - found it!
Best I can suggest is trying another monitor. I'm pretty sure the display will be fine from the other monitor. If you have monitor drivers, you can try uninstalling and reinstalling them - however, I suspect your monitor is probably just an expensive paperweight now.
Sherwin
Dec 21, 2009 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Nov 10, 2017 | Dell E207WFP LCD Monitor
1701FP display problem
Try to do the factory reset. It is on the pop up main menu on the screen by pressing the screen button.
Thank you,
Jan 12, 2008 | Dell UltraSharp 1701FP 17" LCD Monitor
Monitor (Dell 1701FP) flickers, flashes and goes black
Just to check - when the screen is black- can you see any image- in its un-illuminated state. To do this look sideways along the screen not straight at it. I suspect this is an inverter problem. Whether or not this is repairable I know not- depending on your local repair facilities Perhaps DELL can suggest a local agent.
May 16, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor Logo
196 people viewed this question
Alun Cox
