Question about Nintendo Wii Console
When i put in my wii back up disk i got error #0001 unauthorized device detected.. so what does this means? i have a modded console...
5 Suggested Answers
  • 30 Answers
SOURCE: its saying if i don't want to accept an upgrade i
Usually the upgrades are a good thing as they may contain new features or bug fixes, To accept the upgrade you MUST have a connection to the internet, All its saying is the upgrade is optional, you dont have to install it but they recommend it, and unless you have altered things with the hardware you should be fine :)
Posted on Apr 13, 2009
saif123
  • 104 Answers
SOURCE: Wii disk read errors
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-17
Posted on Jul 22, 2009
  • 5 Answers
SOURCE: error 003.unauthorized device detected?
means you need to clean the isc
Posted on Dec 18, 2009
leecom72
  • 4806 Answers
SOURCE: my wii is showing error 003 "unauthorized device
Sounds a hacked Wii. When you updated the firmware found the hack and now your Wii may be bricked.
You can try this: While holding down the reset button, turn on the power to the Wii. If a menu comes up then your wii is definitely hacked but it has a brick safety program to get you out of it. If nothing happens then you may be out of luck.
Good luck.
Posted on Jun 29, 2010
SOURCE: error 003 unauthorized device has been detected
hello
here is some help
http://www.wiihacks.com/bricked-wii-issues-only/26267-error-003-unauthorized-device-has-been-detected.html
Posted on Dec 02, 2010
Unauthorized device has been detected
Error Message: Error 003 Unauthorized Device Has Been Detected
Situation:
System is displaying error message: Error 003 Unauthorized Device Has Been Detected
Information:
This error code indicates the region the system was manufactured for is not compatible with the Wii System Menu update. This incompatibility has made the system unplayable and it cannot be repaired. Nintendo is not able to provide support for these systems.
It has been modified so you will have to buy a new console sorry.
Oct 22, 2012 | Nintendo Wii Console
52230 what does this mean
Error Message: Error 003 Unauthorized Device Has Been Detected Situation:
  • System is displaying error message: Error 003 Unauthorized Device Has Been Detected
Information:
function rvl_ts_sys_error_003_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_error_003",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_error_003_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_error_003_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_error_003_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_error_003_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_error_003_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_error_003_psurvr; req.send(null) } function rvl_ts_sys_error_003_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_error_003=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_error_003_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_error_003_techDif(){ //it broke document.getElementById("rvl_ts_sys_error_003_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_error_003_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_error_003_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_error_003_psurvr; req.send(null) }
Dec 26, 2011 | Nintendo Wii Console
Wii error code 003
Hello
Try this.
The code itself will appear on a customer's screen usually after firmware is upgraded. The screen will become blank with a message of "Error 003: unauthorized device has been detected". The system also notes the error is due to memory, data, or save related issues and provides a phone number to call for assistance.
There is a technique one can use to try to "break" back into the system. This may be accomplished by holding down the reset button while at the same time turning on the power. A menu should appear on the screen with an option to run a brick safety program that can restore device functionality. Keep in mind, though, that this has only worked with modded consoles
Sep 21, 2011 | Video Game Consoles & Games
The wii stopped function after it was connected to Internet . Since then it has been showing on the TV screen" Error 003, unauthorised device detected
If you Wii has been modded (modified) to play burned games or games from other regions and it picked up a software update from the Internet, this can happen.
This typically happens upgrading from 4.1 to 4.2.
If you have not modded the box, you can try to contact Nintendo for repair.
If you did the mod, look at something like http://www.wiihacks.com/bricked-wii-issues-only/33029-guide-how-fix-korean-4-2-error-003-unauthorized-device-has-been-detected.html
for possible recovery tricks.
Aug 13, 2011 | Video Game Consoles & Games
Error 003 , unauthorized device has been detected
Sounds like you accidentally bought a hacked Wii. When you upgrade the firmware found the hack and now your Wii may be bricked. Try this: while holding down the reset button, turn on the power to the Wii. If a menu comes up then your wii is definitely hacked but it has a brick safety program to get you out of it. If nothing happens then you may be out of luck. Since you bought from Korea and it still allows you to play it in America then there is a good chance that your Wii is modded. I would say return it to the person you got it from but that seems to be out of the question.
Jun 25, 2011 | Nintendo Wii Console
I have a Korean Wii. I dont know the system details. I was trying to update the system with a wireless internet connection and I now get the Error 003: unauthorized device has been detected. How do I...
I dont know the system details. I was trying to update the system with a wireless internet connection and I now get the Error 003: unauthorized device has been detected. How do I recover the system?
Jan 24, 2011 | Nintendo Wii Console
Error 003 unauthorized device has been detected
hello
here is some help
Jun 25, 2010 | Nintendo Wii Console
Everytime i turn on my nintendo wii an error message occurs
This usually means the Wii was modified to play other region games and Nintendo has locked it out. In other words, the mod used no longer works and will need removed or replaced.
While holding down the reset button, turn on the power to the Wii. If a menu comes up then your Wii has been modified and won't work again until the mod is removed, assuming if it can be removed.
There is a decent blurb about it here, including instructions for users of Homebrew Channel and Loadmii. I neither use or endorse use of these modifications as it is against Nintendo's AUP/Service Agreement.
Mar 19, 2010 | Nintendo Wii Console
Error:003 Unauthorized device has been detected
where did you get your Wii? did you buy this on the internet? did you mod the wii with a mod chip?
this usually comes from the wii menu/firmware 4.2 update which throws this error when it finds a modchip or region converted wii that came from another country like korea and was change to the region for the USA
Mar 03, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
71 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
