Question about Dell A920 InkJet Printer
Dell 920 printer won't print magenta.
My dell A920 printer won't print magenta. Black is ok and the other cololurs print but look funny without any magenta in it.
  • am85 Mar 23, 2009
    it is still not working and now the blue doesn't print either!
  • b_cindi Apr 24, 2009
    My black cartridge prints with horizontal lines. I have cleaned the heads and run tests probably 7-10 times. It printed a little better when I heated the cartridge. This is an off brand cartridge but this was happening with my last cartridge too. Also, the same "skips" seem to show up when I run the "horizontal clean up." Any other suggestions??? I'm at a loss!!
    Cindi
    Genius:
  • 2,035 Answers
There are chances the magenta ink got over or its dried :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer. try this if this did then heat the cart cartridges walls with hair dryer for 2 min then insert it back and check if it works:
Posted on Feb 24, 2009
Run cleaning utility
  • Clean the Ink Cartridge Nozzles
    • 1 Load printer paper into your Dell A920 Printer.
    • 2 Open the Dell Printer Solution Center on the computer. Click "Start," located in the bottom left corner of your computer. Select "Programs" from the menu displayed. Click "Dell printers." Click "Dell AIO Printer A920" and then click "Dell Printer Solution Center" to open the Dell Printer Solution Center.
    • 3 Click on the "Maintenance" tab and select the option that says, "Clean to fix horizontal streaks."
    • 4 Click "Print." This will print a nozzle print page, which forces ink through all of the nozzles to clean and unclog them.
    • 5 Print a regular document again to see if the print quality has improved. Repeat the cycle up to two more times to improve printing quality.
  • Read more: How to Clean a Dell A920 Printer ' eHow.com http://www.ehow.com/how_6645628_clean-dell-a920-printer.html#ixzz1Dh2DMoc3
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 11, 2011 | Dell A920 InkJet Printer
    I connected my laptop with my dell A 920 and on my computer when i look to add printer it is not listed. It does nto print at all, i guess it is not recognised
    You have to install the printer drivers. Click here to download the driver for DELL A920. Select the driver file according to your Operating System (e.g. Windows XP). After downloading the file, just double click it and follow the on-screen instruction. This will install the printer and you would be able to print.
    Good Luck!
    Hope this helps!
    CreativeTECH
    Dec 13, 2010 | Dell A920 InkJet Printer
    Can the locking mechanism on the Dell 920, that locks the black ink cartridge in place be replaced..
    My wife just had the same proiblem today with the same cartridge carriage. Target's has a Lexmark (which makes this Dell) for $49 which is probabpy better than trying to repair. FYI the ink cartridges for the Dell will not fit the Lexmark.
    Mar 06, 2010 | Dell A920 InkJet Printer
    I can't get the red ink to print on my Dell 920 printer
    What happens when you try to print from the printer. Just try to make a copy of a document from the printer. if that works it should be issue with driver uninstall and riesntall the driver should fix the issue
    Jan 03, 2010 | Dell A920 InkJet Printer
    A920 printer will not print in color & the cartridge is OK
    is there any more colour ink inside? if there is ink inside you just have to open your printers properties dialog and look for a color option that uses black only. 2. see if the colors are blocked
    Feb 07, 2009 | Dell A920 InkJet Printer
    Dell 920 scanning/copier problem
    do you have a driver for vista
    Feb 09, 2008 | Dell A920 InkJet Printer
    Dell A920 Paper will not go into the printer without a jam.
    check cartrages plz your cartrages ok after you clean pickup roller i hope your pro. solve
    Dec 20, 2007 | Dell A920 InkJet Printer
    Dell A920 won't print envelopes
    I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
    Dec 02, 2006 | Dell A920 InkJet Printer
    Dell A920 InkJet Printer Logo
    263 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
