Question about Whirlpool Duet GHW9150P Front Load Washer
Woolpool Duet Washer fast clicking
When we start our Woolpool duet Washer it makes a fast clicking sounds. What's wrong with my washer?
  • Anonymous Feb 24, 2009
    I have the same problem and the washer seems to skip cycles.
  • 50 Answers
If it does not start the clicking noise is coming from the water distribution lever on top of the soap dispenser assembly. Take the top off. On the left hand side you will see a teardrop shaped piece of plastic with an arm attached at one end an a motor attached to the other. There is a stopper that is supposed to stop it from going too far and it has likely jumped over the stopper. Gently remove the arm from the teardrop and reposition it over the stopper then reattach arm.
Posted on Feb 26, 2009
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
My Duet front load washer door will not lock. I
Sounds like you have a door lock failure due to the fault code you have or it could be a control brd failure. Sometimes if either fails it will blow the other aswell.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer sounds like a marble is loose
You washed something from your pockets. coins, marbles, I even removed a nail clipper before. Use a flashlight and try to look through the holes. If you can get front panel off. Put light under tub and see if you can see something that way.
Oct 22, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet washer knocking sounds
From what it sounds, it could be one of the suspension bars. when it's spinning, it is all in the same direction where as agitation is both directions... that would make noise from starting and stopping directions etc. it could be a few other things... please let me kno if you need more help.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet
try hitting pause cancel twice if that doesnt work turn the dial around all the way to off try to unplug the washer if all that fails the remove the three torx screws remove the lower panel and reach up where the latch is after unpluging the washer on the bottom of the latch is a tear shaped tab pull it down till it clicks that will unlock the door
Mar 30, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet Washer Wont Drain
Sounds like a relay on the board. Have you tried to reset the machine by switching it off at the wall and leaving it for about 20 seconds before switching on again?
Oct 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal De
