Question about HP Pavilion dv6000z Notebook
I have a problem with my HP dv6000. I tried to remove the BIOS password, and then it went into 04839 halt-mode, and since then I cannot seem to be able to start my system normally because when i restart, it comes to the ENTER PASSWORD Screen (BIOS Password), then it stop there. I keyed-in the last sucessful used BIOS Password, and still, it DOES NOT work. Is there any default password i can use to go into the BIOS to change it to a password of my own. How to be able to bypass that BIOS password screen ????? Thanks REZA
  • Anonymous Feb 27, 2009
    DRIVERS
  • RescueTechLA
    RescueTechLA May 11, 2010
    How long ago did you purchase this laptop?
  • HP Master
  • 629 Answers
A BIOS password reset can fix this issue. You may request HP support for a BIOS password reset. They may need to request for a system ID or the error you are getting when you enter the BIOS password.
Posted on Mar 01, 2009
Bios password lock out Halt code : 84942828
Try this password:
InsydeH2O BIOS (Acer, HP) 31620208
Fujitsu- Siemens 79957929
Jun 12, 2016 | Computers & Internet
Need bios password for hp pavilion 15-b119wm halt code 92917435 please somebody help
For BIOS passwords you need to contact HP Support directly since only them have records of passwords for particular devices.
Oct 18, 2014 | HP Pavilion Sleekbook 15-B119WM Black...
Hp tx2000 bios password
I can get the bypass code from HP all you need to do is type the wrong password in three times and give me the system halted or the system disabled code. It can take about 24 hours to get a code back. Hope this helps.
My YouTube
Live Tech Support
Apr 25, 2013 | HP Tablets & eReaders
How to remove BOIS password for hp 6720s? battery is removed but still blue screen with key on it
1) Turn off computer
2) Disconnect AC adapter
3) Remove battery pack, and remove the laptops keyboard
4) Disconnect RTC (Real Time Clock) battery (located underneath the keyboard, the red/white wire)
5) Leave off for fifteen minutes
6) Reconnect the RTC battery and reassemble the laptop
7) Reconnect AC adapter (DO NOT REINSERT THE MAIN LAPTOP BATTERY AT THIS TIME!)
8) Turn on the computer and enter the BIOS by pressing F10
9) Set the new BIOS password and save all settings.
10) Turn off the laptop and reinsert the battery
Hope this helps ...Lee
Nov 07, 2011 | HP Compaq 6720s Notebook
Dv6000 will not startup ,Black screen , hd isnit being accessed
When you first turn the laptop on is there a HP splash screen? Can you enter the BIOS (normally by tapping F2 or Del key). If so then it would seem the BIOS updated OK. If when you turn it on there is nothing the BIOS flash probably went wrong and the machine will need a new BIOS flash chip installed.
If you can access BIOS then it may be a simple problem that the new BIOS reverted to default values. The most common issue would be the boot mode of the HDD. Look through the BIOS menus and there should be an option for boot which will say AHCI/IDE/Compatibility. Try changing it to another option, save and exit BIOS and see if that helps. Try this for each option.
Alternatively tap F8 continuously when you turn the laptop on and see if the advanced boot menu appears, if it does try selecting Safe mode with networking.
Finally to test if the HDD is actually working, try downloading Hiren's BootCD and boot to it. Then run some HDD diagnostics to see if the HDD is operating correctly.
Hope this helps,
www.PuterCare.com
Jul 07, 2010 | HP Pavilion dv6000z Notebook
Can't remember my password on hp 6000 computer how
Are you talking about the BIOS password, or the windows password?
A hard reset will probably reset your BIOS password (see this thread),
To reset your windows password, you need your XP CD-ROM and follow this instruction.
Jan 02, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
How do i remove bios password on my hp 6730s?
On HP DV6000 series laptops, to clear the BIOS password, find the Cmos Battery (or RTC battery) and disconnect it from the motherboard for at least 10 minutes. This will clear the CMOS and clear the passwords. This is straight from the service manual. Once the time is over reconnect the battery and power the system back up, make sure you go right into the BIOS and reset the date and time. This is usually accomplished by striking the delete key or the F2 key during the HP splash screen.
Sep 28, 2009 | HP Compaq 6730s Notebook
Hp pavillion usb ports
They are right, some DVs have this problem. If you can live without the ports, then do it. If you can't, replacement is the only option.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
Dell latitude d620 bios password removal
I got my Dell Master Password from http://www.bios-password.kickme.to/
This seems the best price in the net
Jun 20, 2008 | IBM ThinkPad T43 Notebook
HP Pavilion dv6000z Notebook Logo
657 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
