Question about Motorola Mobility RAZR V3i Cellular Phone
Need more storage space to update Media Finder on my Motorolav3xx
When I try to access my Pictures in my Media Finder a notice shows; "Need more storage space to update Media Finder." I have taken out the battery and cleaned the phone as well as the sim card. It shows that my pictures are all gone, but my wallpaper is still showing and it shows that my ringtone is gone but it still rings as if its there?
I recently downloaded phone tools to transfer my phone numbers. Is there a possibility I transfered a virus?
  • Joe
    Joe Mar 07, 2009
    Thanks bud. I appreciate the very descriptive helpful solution.
  • 653 Answers
I went to the Motorola website and pulled up information on the RAZR V-3i, and it does have a memory card slot to add more storage. Look on the top of the phone for a little plastic cover that you can flip out with a thumb nail. It should say Micro SD on the cover. Since your RAZR is like my ROKR (they are nearly identical on most functions except for yours is a flip phone, and mine is a slider) you can insert a micro SD card with the copper electrodes facing downward toward the front. Your manual will probably specify up to a Lexar 2 GB (giga byte) memory card. I have about 36 hours worth of music stored on mine, and still have room for a few pictures to download later. The manual should walk you through transfering file from internal memory to external memory. Sorry about the jerks out there.
Posted on Feb 25, 2009
Kycoera hydro life camera message phone storage full what does this mean
Your phone has internal storage, files such as pictures, music, applications, etc...take up space on your storage. Specifically, photo's, take a large amount of space.
To fix this you need to either delete some applications or pictures. You can also connect the phone to your computer via USB, and transfer the photos to your computer, then delete them off of your phone. Lastly, if you have an SD card on your phone, you can transfer the photos to the SD card instead of the internal storage.
Once you delete some files, you should have the space to start snapping again!
Feb 23, 2016 | Cell Phones
An alert comes up saying my storage space is running out.
try to delte some apps which is not important to u and to ur phone. bcoz having alot of apps installed to ur phone it will ruin ur phone and get slower and slower, and try not to update some apps which is not important to u and can harm ur phone
Aug 31, 2015 | Cell Phones
Cannot download anything, insufficient space on device
Hi Izabel Maritz, I want to help you with your question, just answer each of the following to the best of your knowledge and follow the solutions. 1 Smartphone or not. 2 Removable media inserted? (Micro SD card) 3 Does the Removable media device show unused space? First and most importantly if you know a Micro SD card is installed with sufficient space to save your downloads then your phone settings are set to save downloads to 'local storage' and has filled to it's max. Often you can fix this easiest by removing the card for a few seconds and re-inserting it whilst the phone not 'locked'. Most phones will prompt you asking if saves should now be made to the SD card or to leave it at 'local storage' If you answer yes to each of the above numbered questions, it is likely the browser you are using is set to download to the incorrect destination. Try Solution A below. If answers no to questions 2 or 3 of the above question skip to Solution B. (Solution A) To check this open your browser and look for the settings menu. From here it will depend on the browser you are using, but you want to look for an option related to the following. 'download location' 'file destination' 'save to external media' If you have no success or need help finding the setting for your browser please provide me with browser name. If it is the cell phone provider browser that comes default on the phone then I will need the make and model of the phone. (Solution B) If no Micro SD card is installed to your phone I would recommend buying one they are inexpensive and provide a large amount of space for things on your phone. The average phone whether it is smartphone or not does not have much 'local storage' Other solutions for B, 1 Freeing space in your local storage. This means deleting things saved to the phone itself. Music, Pictures, Ringtones, Video's, Applications could be filling the phones local storage. 2 Freeing space on your 'external media' device. This means deleting things from your 'Micro SD card' (Note. If you plug a phone smart or not into a PC or laptop usb port you may move things rather than delete them. I can assist further with that as well.
Nov 25, 2014 | Cell Phones
Why do I get you tube error loading messages when trying to access you tube videos on my I pad
Most likely your iPad is full... of pictures, videos, music, etc. Visit the Settings app, tap General, then Usage. In the STORAGE section at the top, you'll see how much of the storage is available on your iPad and how much is used. If the available number is small, you need to remove stuff until you have enough to handle incoming video streams (YouTube, for example).
The STORAGE section also identifies the apps that are using your space - if Music, Photos & Camera, or other apps seem to take a large portion of the space, either remove some of the data associated with those apps (pictures, movies, music) or remove apps themselves (apps you don't use don't need to be taking space on your iPad).
Portable devices aren't meant for large permanent storage. You should save things you intend to keep forever on your desktop device or in the cloud.
Oct 18, 2014 | Apple iPad 2
I have a Z796C ZTE phone and whenever I try to download an update or an App, I get a message that states that I have insufficient storage space available. The phone has 1.61G
Well with the information you supplied, it sounds like you have a phone full of pictures, (small files) video clips, (big files) and apps (some small, some huge) and prior to updating your phone you will need to delete enough to install your updates. The 1.61G is what? Empty storage space? Processor ? If you want more help you will have to take the time to actually give more information. Because that phone has 4 GB of built-in storage... Is it new? Is it full of pics, vids and apps or is there an out of the ordinary reason you get the message. Are you installing the app in the correct place?
Sep 22, 2014 | Cell Phones
Internal phone storage space nearly full
How to Transfer Apps Pictures From Internal Storage to Micro SD Card...
The above page shows a method to move files to an SD card without you having to install an app. That should free up space. There are apps that can assist with this process but you may be so short of space that you need to move some with the above method (before you can even install another app). Note that you can actually move applications to a SD card as well as photos or books or music. Some versions of operating systems restrict access to SD cards. If you experience a difficulty, you may want to access the help and support for your particular phone model and operating system version. Check for that on the brand site.
If you find this helpful, please tick the helpful box.
Oct 10, 2017 | Samsung Cell Phones
Problem with my ANDROID phone!
Its because your media player library is not getting refreshed. Check whether there is a refresh option in your player settings. Or else you can try any other 3rd party players like Poweramp, which can be downloaded from the Play Store.
May 05, 2017 | LG Cell Phones
Phone stuck "Updating Media Finder"
Pull the battary while phone is on. Wait a few seconds and replace battary. Do not try to turn phone on. It will take a few minutes to reboot. This updates everything.
Dec 24, 2009 | Motorola Mobility Karma QA1 Cell Phone
Memory is Full
I think, you have tried an online firmware update. Please let it finish. Memory full does not always means the storage is full. At technical world, memory actually means the Ram. You must not keep open many programs. Please try closing them to get free memory.
Unnecessarily opened programs take the memory.
Apr 21, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Pes2008
That's the best way to do over your PC to your USB. Create a folder on the storage media in which to save the update data.
Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  • Download the update data and save it in the UPDATE folder created in step 1. Select here to start the download.
Notice
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data.
  • File name: Save as file name “PS3UPDAT.PUP”.
    Update procedure
Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select (Settings) > (System Update), and then press the button
The folder name must be in all uppercase letters.
    Update procedure
Notices
  2. From the home menu, select (Settings) > (System Update), and then press the button.
  3. Select [Update via Storage Media], and then press the button.
    The system automatically searches for and finds the update data saved on the storage media or USB device.
  4. Start the update data.
    Press the button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to (Settings) > (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
You can delete the update data from the storage media or USB device after the update has been successfully completed.
Jan 06, 2008 | Sony Playstation 3 (PS3) Console
Motorola Mobility RAZR V3i Cellular Phone Logo
221 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
