Question about Sony Playstation 3 (PS3) Console
No sound or picture?
Scart connection not working? bought new connection still no sollution, tried on several television sets-nothing???
    President:
  • 2,653 Answers
Start with a video reset.
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 24, 2009
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
Bought my ps3 when it came out been really good till naw . it will switch on disc will go in everything sounds like it works but i get no picture tried a new scart lead and still nothing.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • This is from playstations website Hope this helps.
    Nov 22, 2010 | Sony Playstation 3 (PS3) Console
    Turn on tv, no picture no sound, shined light into screen,nothing
    Check your connections and scart leads, take them out and put them in again. It may be a loose lead or maybe a faulty lead, swop them over to see.
    Apr 28, 2010 | Olevia LT32HVM 32 in. LCD Television
    Sound but no picture
    ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
    Feb 06, 2010 | Televison & Video
    Problems with Lenovo 3000N200 0769-EAG tv-out
    My friend, the easiest and by far the best way I have seen is to set the advance timings on your laptop just right and use a vga to scart cable.
    Restart your Laptop to recognize again your TV on the system.
    Aug 23, 2009 | Lenovo 3000 N200 Notebook
    AWA set top box STB232 connected to Panasonic LCD
    Loss of sound is often a SCART connection problem. Check that the SCARTS are pushed in securely. Or if the SCART is old, it may be faulty. Try a newer one, or one that you know is definitely ok.
    Mar 21, 2009 | Televison & Video
    Samsung le40a lcd - picture quality
    Hi - I have some suggestions. The following factors effect picture quality:
    1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
    DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
    Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
    The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
    Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
    Hope that helps!
    Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
    Panasonic TX32LMD70: split and green picture from DVD
    Cut feed lead to pin 16 (in the scart not the equipmend!)
    Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
    Jul 04, 2008 | Televison & Video
    I bought a Toshiba 42'' plasma TV exactly 1 year ago. The model, as per the hand book, is 42PD6600 A. About 8 weeks ago I began experiencing some problems to turn on the TV, i.e. the red light (stand...
    maybe your ac cable has a lost contact thats why when you wiggle it it will turn on. just replace your power cable first before you are going to troubleshoot the other problem.
    regards,
    janex
    Apr 22, 2008 | Televison & Video
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
