Question about Samsung CLP 300 Laser Printer
Samsung CLP300 cover pops open while printing
After sending a job to print, the printer starts making loud grinding noises as though a gear is slipping. After a few seconds the right side of the front cover will pop open and printing will stop.
I am able to finish printing by forcing the front cover against the printer with my hand, though I feel the printer pushing the cover into my hand. As soon as I let go, the door pops open and printing stops.
  • Paul Edmunds Feb 24, 2009
    Solved for now?
    The cartridge was not fitting in properly.
    Sure enough, this had only started happening after a new black toner cartridge was installed. This was not a refurbished cartridge.
    We found there is no "click" as the cartridge is pushed into the imaging unit and the plastic gear on the back of the black toner cartridge was not moving freely. We rotated the gear on the back of the toner and re-inserted the cartridge into the imaging unit.
    We printed a few jobs with the cover off (manually pressing the switch that the cover activates when closed) and the printer ran well with only a little noise.
    My guess is that the new cartridge isn't fitting in 100%, or the gear on the back of the cartridge is not fitting perfectly into the gear behind it on the printer, which caused the cartridge to pop out, pressing against the front cover.
  • Melrin Mar 07, 2009
    Hi Paul and others,
    here is my opinion:
    Quick solution: Change developer unit
    Detailed description:
    your grinding noises starts after cartridge is pushed out about 2mm,
    gear on the cartridge is off support (axial plug inside printer) and force between gears axis draws apart axes of gears.
    If you will keep cartridge in original possition, pressure in the cartridge will increasing and agitator inside bottle destroyed.
    That increased force appears when toner is not freely moving from bottle to developer unit (when toner cartridge is not near empty) during Toner Supply Mode.
    Simply... developer is overfilled, but printer is still loading toner by
    moving cartridge.
    You can make these tests:
    1/ You can see in circle hole in developer toner around vertical supply hole, and toner level is visible. On colour developers I have no visible toner level.
    2/ You can rotate gear on cartridge to left (anti-clockwise) when it is out
    of printer of course, and the fill hole down. After a while the gear will stop moving by increased pressure.
    This only my opinion, but all cartridges I have tested had this freeze on toner pressure. Empty cartridge moves freely, but empty chip is cause not usable for more.
    Maybe this sitation can rise when you print all pages (about 2000 on this toner) with very small toner coverage of page, so chip is counted off and toner has full level in developer.
    So, I think, printer has an error in firmware or in checking toner level in developer, therefore I upgraded to new firmware v1.00.12.35 and now testing if toner supply mode is resolved. (I hope, this is associated with Release note of FW : Toner save mode by optimized toner supplying :o)
    Sorry, if my solution is not solution for you, but for me is working few days...
    I am waiting for your comments...
    Problem Solver:
  • 6 Answers
If you used a non samsung toner cartridge replace it with another of a different brand or a samsung one. when it pushes the cover open look to see which toner cartridge is pushed out and replace that one
Posted on Jan 10, 2010
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Printer making a loud clicking noise when printing.
the feed roller gear is stripping; remove the cover and, adjust the gear retainer before it completely fails. (it should be easy to see the gear once the printer cover is removed.
Mar 30, 2010 | Dell 1700n Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
What causes the tapping noise when I print documents?
Could be a faulty toner.
Check if the gears on the tonercartridiges still rotate. Had this problem on a CLP300 a while back : locked gear on the Black toner, causing a "snap-like" sound during printing.
So take out each colour, and see if you can rotate the gear protuding from that cartridige.
Mar 26, 2009 | Samsung CLP 300 Laser Printer
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 Makes Grinding Noise when printing starts
I had this same problem and called tech support. Instead of sending a new printer they had me
1 remove print Cartridges
2 remove print head
3 replace print head
4 replace print Cartridges
5 unplug power from the wall
This seemed to fix the problem.....for me anyway.....for now.
hope it helps
Dec 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Samsung CLP 300 Laser Printer Logo
296 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
