I have a Gateway laptop, Model M-456-E. I did a "restore", but it obviously did NOT get the video driver for the LCD right. The screen keeps recycling (refresh) on both the laptop and the #2 LCD. I know that Gateway has gone away, but how can I locate and download the correct video driver?? Help please! **** Truex
  • rtruex Feb 24, 2009
    OK. Not sue how to re-connect, but would like to continue and then have you look over the laptop - IF you can get in [remote]?? **** / rtruex@citlink.net / 703-731-3540
    President:
  • 2,653 Answers
I got this one.
Posted on Feb 24, 2009
  • RescueTechLA
    RescueTechLA Feb 24, 2009
    I got cut off, they're updating the fixya website chat function so they pulled the plug on us.
    I'll try to answer this question for you offline.
    I'll be back online in 45 minutes. It's 8:46 am pacific time right now.
  • RescueTechLA
    Richard,
    Don't forget when you visit Windows Update to choose "custom" so that the hardware drivers will pop up. Let me know what happens.
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
I can not get my screen resolution back on my gateway laptop it wl not allow me to increase for some odd reason
Try a system restore and bring computer back before this was a issue, if no change! go online to Gateway to see if they a new update for the video driver.
Mar 30, 2012 | Gateway Computers & Internet
I have a gateway kav mini laptop when I turn it on the left side of the screen show ok but the right doen't. It has a shadow box and it that side of the screen flickers. How can I get the screen back
Try doing system restore..check if that works else contacst gateway..your laptop's lcd needs to be replaced at 800-846-2301 for further help contact me again thanks
Nov 05, 2011 | Computers & Internet
I have GATEWAY LAPTOP model mx6424 with windows vista home primium, service pack 1. but i have no sonud, i got like this massage. THAT ''NO AUDIO OUTPUT DEVICE INSTLLED'' PLZZZ,HELP ME.
Hello !
1. I have some solutions for you i hope.
Below is a link to a support page on gateway but you have to find your model nr to be sure its the right driver.
http://support.gateway.com/support/drivers/search.asp?param=sigmatel
2. Below is a link to page for buying restore-disk for gateway
http://restore-disk.com/restoredisks/Gateway/GatewayMX6424/Gateway-MX6424-Vista-Restore-Disk-145022.html
3. On this page you need to be a member if you want that driver.The problem today is that we all have to pay for every driver when we need them for our computers and stuff.
http://members.driverguide.com/driver/detail.php?driverid=1630218
if none of this will work the best thing is to maybe install windows xp instead.
Good Luck and
Best Regards
Joakim
May 18, 2010 | Gateway MT3705 Notebook
My graphics driver keeps shutting down
make sure u have the correct amount of ram allocated to your internal video card thru your bios settings download your owners manual from gateway to get to your bios and set back to setup defaults should be F2 F6 F10. and another issue could be your recovery cd is outdateded.. u might have updated your bios firmware so now your motherboard chipset firmware that is on your restore disk is causing a irq failure
Apr 16, 2010 | Gateway MT3705 Notebook
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Can i replace my Gateway laptop tft screen with a new lcd screen?
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Jul 29, 2009 | Toshiba LCD TFT Monitor
Profile 5.5 during startup screen goes blank
If the video card is an "onboard type" Is is not easy to replace.If you have a seperate video card, you may replace it with a like type, PCI, AGP,PCIe,etc. or if you computer has an open slot a video card can be added and turn off the "onboard video" in start up screen BIOS .    Since this is a GATEWAY(I do not know the model) computer you also always have the option of a complete restore . Below is their website to download al the info:
Dec 29, 2008 | Gateway Profile 5.5 PC Desktop
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
