Question about Lands Phones
2.4 GHz vtech cordless phone won't connect
Why can't it connect? The wires aren't tangled. The batteries are phone. Will resetting the phone work? How can i reset it
  • Anonymous Mar 27, 2009
    I have 2 of the 4 handsets that will not connect after I removed and replaced the battery. This is a 5.8 Ghz Digital set. Two of the phones work fine.
SOURCE: GE 5.8 GHz Cordless Phone model # 25836 EE1-A
hi all called thompsons becasue mine did the same ...they said to reset phone un plug ac then phone line from base then remove battery them let set for 10-15 min . re hook up and its back to basics.
Posted on Apr 17, 2008
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Posted on Jul 09, 2008
SOURCE: user manual
need copy of manual for vtech 5.8ghz cordless phone with 2
additional handsets in english.
Posted on Dec 19, 2008
  • 3 Answers
SOURCE: Phone won't hang up
I solved this exactly problem by doing this:
1) unplug base station from phone line
2) unplug base station from power cube
3) open each phone and disconnect battery (do not replace phone in charger; just let it sit)
4) wait 30 minutes (per instructions from Uniden)
5) reconnect batteries in phone sets
6) reconnect power cube to base station
7) reconnect base station to phone line
8) test: make a call. Hang up. Wait one minute. Pick up line and see if you get a dial tone.
(Basically you're "rebooting" the system. You don't know where the fault lies, so you power down every component to make sure you get it. The '30 minutes' is longer than I'm used to, but after being on hold with Uniden tech support for 20 minutes and finally getting through, the instructions from them were very clear: AT LEAST 30 minutes. OK! I did it - and it worked!)
Posted on Jan 21, 2009
SOURCE: vtech 5.8 ghz phone with voicemail
please help me out
Posted on May 05, 2009
NEED OWNERS MANUAL FOR VTECH 5.8 GHZ DIGITAL ANSWERING SERVICE
Since you declined to specify the model of your VTech 5.8GHz cordless system, I can only suggest that you enter it into the search box here to download a copy of the manual.
Apr 22, 2012 | Vtech 5.8GHz Analog Cordless Phone
I have a three handset 6.0 v tech. the one handset keeps beeping. What is going on?
With vtech phone (many times) a beeping handset indicates a low battery or an inability to connect to base station. check to make sure the battery is connected correctly and that the phone is setting in its docking station correctly. (remover and obstructions that would prevent correct charging) If this fails go to your local store that sells batteries for cordless phones and purchase to correct type.
Oct 13, 2010 | Vtech 5.8 Ghz Handset Cordless Phone...
Can open battery back on cordless phone
I had to use a knife to slide under the top of the release area and pop it out. It wouldn't slide like it is supposed to. didn't break it....
Jan 01, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Phone wont connect to verizon. message on phe says place set in
Unplug main unit and the other unit which is not working then plug back on after few minutes. If its still the same then change battery on hand set. baattery life is only four years
Mar 26, 2009 | Vtech 5.8 Ghz Handset Cordless Phone...
User manual
Nov 17, 2008 | Vtech IA5854 5.8 GHz Cordless Phone
Does not keep charge
Vtech 5.8 GHz does not keep the charge and
characters & numbers look choppy
Thank you
Jul 12, 2008 | Vtech 9009111 Cordless Phone
Low battery
You need to buy new batteries for your phones. Large retailers charge $10-12 per battery but you can usually find them for closer to $4 online at amazon.com or eBay.
Jun 22, 2008 | Vtech 9009111 Cordless Phone
Vtech 5.8 GHz and says cant connect
Mine turned out to be not getting power from the surge protector.  Plugged it into the wall and it worked again.  If the power light is off to the base station it is not getting power and won't connect.  I know this is a duh, but I missed it.  Probably not what is wrong with yours.
Nov 19, 2007 | Vtech 5.8GHz Analog Cordless Phone
Lands Phones Logo
728 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
