Question about IBM ThinkPad R50e Notebook
I want to do a factory reset on the thinkpad R50e, pressing the blue ibm access botton dont work anyone have any ideas, have done this in the past and cant remeber how?
  • Bastian Farkash
    Bastian Farkash May 11, 2010
    Have you doen any Re-Partitioning and or Formatting (Maybe Installeda OS over the Top, i.e clean install) since you last did a factory Reset? If so you might have ruined the ability to do a Factory Reset by modifying the Partion where the Pre-Installed Files are.
    Maybe the Blue Keys function has been disabled if possible Y/N?
    Ok just read the manual and my guess is dependant on your feedback.
I want to reset my laptop to factory settings
If you have a Factory Recovery Partition, Reboot and use the procedure in this forum: http://forums.lenovo.com/t5/R-and-L-Series-ThinkPad-Laptops/Product-Recovery-Windows-XP-ThinkPad-R50e/td-p/92036 OR, If you have the Factory Recovery Disks, put Disk 1 in the CD ROM and reboot, OR contact IBM for a Set of Factory Recovery Disks, if available.
Mar 01, 2013 | IBM ThinkPad R50e Notebook
Would like to reset my ibm laptop it says my mircosoft online service is temporarily unavailable and my laptop is slower than ever
Hi and welcome to Fixya1
To reset the machine back to the factory settings, just follow these steps:
    • 1 Shutdown your machine and make sure that the charger is plugged in before doing the reset. Turn on the machine.
    • 2 Press the blue Access IBM button on your ThinkPad keyboard at the screen prompt. The screen prompt reads "To interrupt normal startup, press the blue Access IBM button." This interrupts the Windows reboot process.
    • 3 Double click "Recover to Factory Contents" at the Access IBM predesktop menu.
    • 4 Follow the recovery wizard prompts to initiate the factory restoration process. Your ThinkPad will automatically reboot upon completion.
Hope this helps!
Takasashi
Jul 19, 2011 | IBM ThinkPad R40 2722 Notebook
Restore default settings for ibm thinkpad r50
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD. Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD. thanks and have a nice day J-
Nov 26, 2009 | IBM ThinkPad R50e Notebook
Factory restore will not show
You may need the system restore disk to complete that task if the computer has other issues going on.
Sep 07, 2009 | IBM ThinkPad R50e Notebook
I want to reset my IBM thinkPad R50e back to Factory settings, I am running Windows XP Proffesional and have no restore disc.
CREATE A BACK OF DATA INIT
BETTER THEN RESTORING U CAN RESTORE UR SYSTEM TO A PERIOD WHEN UR THINKPAD WAS RUNNING SUCCESSFULLY AND THIS DOESNT DELETE ANY DATA ON UR HARD DISK
START PROGRAMMES ACCESSORIES
SYSTEM TOOLS SYSTEM RESTORE
THIS WILL SURELY HELP U
Aug 25, 2009 | IBM ThinkPad R50e Notebook
ACCESS IBM
you are missing the hot-key diver. For the thinkpad R50e, you can download it here
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html#utility
May 06, 2009 | IBM ThinkPad R50e Notebook
IBM R50e thinkpad - where is the reset button?
keep your power button pressed for 3-5 seconds to reset.
let us know the results, thnx
Jan 30, 2009 | IBM ThinkPad R50e Notebook
Ibm restore to factory setting
You have not explained what is wrong with your computer.
Is the laptop working, does it boot up into Windows?
What are you trying to restore?
Are you trying to get into a previous Restore Point?
The Access button takes you into the BIOS, you can change the BIOS settings back to the Default settings (ie the factory default settings).
It is difficult to offer a solution without knowing the exact nature of the problem.
Nov 23, 2008 | IBM ThinkPad R50e Notebook
How to reset to factory setting . i have ibm thinkpad r50e.
Turn your unit off.
then turn it back on.
Watch the display carefully, Press the Blue Access IBM button when you see the message
"To interrupt normal start up, press the blue Access IBM button"
Then double click on "Recover to factory contents"
Follow the instructions on the screen.
When the Recovery process finishes, press enter.
Your computer will start with the pre-installed OS, Drivers and software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
IBM - Access password problem
sorry if someone accessed the laptop and placed a password on it I can not help you nor can anyone except whomever placed the password on the laptop. Sorry
Apr 27, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad R50e Notebook Logo
279 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
