Question about Kodak EASYSHARE 5100 All-In-One Printer
Cannot communicate with printer error
I have a Kodak AIO 5500 and a computer running Vista Ultimate. Replaced the printhead after about a month. Software installs,sees the printer, installs the drivers and then indicates that it cannot communicate with the printer. Error window indicates to check the USB cable. Replaced the cable, tried different ports, spent over an hour with Kodak support with same results. Uninstalled software, used Kodak clear utility to perform a clean uninstall.Used ccleaner to look for registry entries left behind. Deleted printer from printer window while unplugged and plugged it in to let windows find it and reinstall it. Same thing happens,It indicates that the drivers are installed and the device is ready to use, then a red x apppears over the printer icon in the task bar and it errors saying that there is a communication problem. Plugged an HP 1320 printer in using the old and the new cable, both times installation was handled by windows and the printer worked with no errors. Reinstalled .net 2.0 at the insistance of Kodak with same results. Program logs in Vista indate that the Kodak services and the Kodakdiscover crashed and closed. Kodak diagnostics report indicate error code 3503, 3501, 3502. Kodak could not tell me what the error codes mean. And ideas?
    Scholar:
  • 60 Answers
Error codes that you mentioned are not related to your issue you will get those are for front access door open and main paper tray empty.........the number of times you open the front access door and when ever the main paper tray is empty you will get that error.......you mentioned that HP printer worked......i would recommend to use a clear utility for HP and remove all the drivers and software for HP first as that might be conflicting with Kodak and make sure the version of the software for the home center(which includes drivers) is latest which is 3.4.......you can check for the version of the software by opening the home center and click on the question mark on the top right and then click on i which is on the right in the new pane that comes up and you will be able to see the software version in the right hand bottom corner on the small window that comes up.......if you have the latest version of the software then make sure you have the latest chipset drivers on your computer......for that you can contact your system manufacturer.......i suppose you have Dell...........if that also does not help then just tell me what all options you have under the Universal Serial Bus Controller.........also make sure if you have printer icon in the printers and faxes in case of XP and under printers in case its Vista.......if not then try and add a printer icon........if you already have a printer icon then try and right click on it and set it as default printer and then check if it works............let me know whats the result and was this helpful or not..............
Posted on Jul 16, 2009
How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Nov 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5500 AIO easy share printer will not print black ink.
follow the step by step solution from kodak.
Choose All-in-one printer and then Print quality and follow the further steps. I think it's a problem with your printhead.
Oct 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lousy Color - Lousy Printer
Kodak is sending me ANOTHER replacement printhead .... third replacement in 19 months.
Jul 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to install a new printhead
Hello ljohnsonmedi,
To install the printhead for 5500 as well as all kodak AIO Printers, you need to put the printhead inside the carriage and then push the top of it with the sticker in it and then you should hear a snapping sound to confirm that it is properly placed.
I hope I have been of some help.
Nov 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brand new easyshare printer - says that printhead is not aligned
Even though the printer says that you shouldn't return it to the store if you have trouble, I strongly suggest you to do that.
If you don't want to, you can call the Kodak AiO Support so they can help you replacing the printhead or the printer if necesary
Sep 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Replacement of ink
Download the newest firmware from www.kodak.com. Try reseating the printhead - see user's guide. If that does not work, email or call Kodak AiO tech support.
Jun 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Not printing black
Needs new printhead. Write Kodak support and they over night it.
May 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Black INk Problem
Try calibrating and cleaning the printhead in the kodak aio home center software.
Dec 19, 2007 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
251 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
