Question about Nintendo DS Console
Screens flickering then switches off
Switched my ds on this morning and the bottom screen was very dark and i could barely make it out, then it started flickering. the top screen then started doing the same and now they're both dark and it switches itself off after a few seconds. any idea what mey be wrong? i only got it for xmas and i love my ds!!!
  • NdslER Apr 11, 2009
    I have a similar problem only the bottom screen is dark and flickers like a strobe but everything else works perfect touch screen plays games etc I have installed a new LCD screen on the bottom but it is still the same as last time.
    Any advice would be GR8
    President:
  • 2,653 Answers
Sounds like a hardware problem. If you got it for xmas then it's still under warranty.
http://www.nintendo.com/consumer/manuals/warrantyinfo.jsp
Best of luck!
Posted on Feb 24, 2009
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
Ds lite- green light comes on then screen flickers for one second then turns its self off whats wrong ?
Hi there, this is usually a sign that one of the screens has become faulty.
When you switch the DS console on, make a note as to which screen is the one that flashes. If the top screen flashes just before it turns off then the bottom screen is faulty.
If the bottom screen flashes then it is the top screen that is faulty.
Whichever screen it is that is faulty they can be bought quite cheaply online from places like amazon and ebay.
To actually replace the screen does require some good technical knowledge but usually there are some very good guides available just by doing an internet search.
I hope this information helps you and thank you for using FixYa
Apr 17, 2011 | Nintendo DS Lite Console
My nintendo ds shuts off everytime i turn it on
Judging by you saying that it shuts off would suggests that it has power so the battery and charge is not an issue.
When you switch on the ds you should see one of the screens flicker on just before it powers back down.Which ever screen does not flash had a problem, the connection haseither come loose or the screen has developed a fault, in which caseyou will either have to send it away if its under warranty, take it toa local repair shop or replace the screen yourself.
Firstly whenyou take the ds apart disconnect the relevent screen and thenre-attatch it just to be sure if its the connection or not, if are-connection works then your sorted... if not you will have to replacethe screen.
The screens, both top and bottom can be bought fromebay. If its your top screen you will also have to do a bit ofsoldering as the speakers will need to be removed from the old screenand soldered onto the new one. If its the bottom screen you will needto carefully seperate the touch screen from the lcd screen2_bing.gif.
If you need any more help with changing the screens then give me a message and I will do my best to help you out.
If none of the screens flicker then get back to me and I will help you figure out whats going on.
Regards,
SOD69
Feb 02, 2010 | Nintendo DS Lite Console
Bottom screen on ds lite flickers
check the cable first it might not be in the ribbon connecter properly, if everything looks ok chances are youll need to replace the screen.
Jan 17, 2010 | Nintendo DS Lite Console
Screen went almost completely dark, can barely see at all.
I had a similar problem with an HP DV2000 notebook computer. Here's the solution for the HP model DV2040TX: Problem identified and FIXED. Not the screen, not the screen power supply. The problem was the micro-switch within the right-hand-side screen hinge. This switch turns off the screen when you close the lid of the notebook - probably to prevent overheating. The switch had failed mechanically (technical term: "fallen to bits"). As a low-cost fix, I have unscrewed the main casing including the screws inside the battery compartment, removed the silver panel covering the speakers, flicked the switch "ON" using a jewellers' screwdriver, and removed the small metal tongue that is operated by a cam on the hinge. Thus, the switch is PERMANENTLY ON. Computer operates normally, shuts down normally using Windows. Just need to be aware not to close the lid without shutting down the computer beforehand. Hope this helps you. All the best, OzKluger
Jan 23, 2009 | HP Pavilion dv2000t Notebook
Ds touch screen and main screen not working - connectors broken
if you would have sent it to me first I would have replaced the case for you and you wouldn't have had these problems, but I can still help you out. I have a white nintendo DS lite in stock that I had to replace the bottom lcd display in. I will ship to you for $90 and if you are feeling adventurous send me your parts and I will take off $10 since I have no clue what is broken and what is not, but to me it sounds like the bottom lcd, touch screen , and circuit board are trash.
Thanks
Josh Boyer
ninja_freak318@hotmail.com
Jan 22, 2009 | Nintendo DS Lite Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
Laptop screen
Sounds like the switch that tells the cpu when it's open or closed is going bad. On most laptops there is a little switch that protrudes from your keyboard (usually in upper corners). Try cleaning it with isopropyl alchol(rubbing alchol) and a q-tip and see what happens. If you can't locate the switch on your model get back to me and i'll research a little deeper for you. Hope this helps
Sep 14, 2007 | IBM ThinkPad 770 Notebook
Ds not lite
Replace the connector cord between two screens. You can buy new ones from DX Deal extreme! Carefully remove through hinge and attach securely.
Be careful not to break the fine wires connecting. Have to twist the connector cord in the correct way to make it go through hinge without damaging.
Good luck cos it is a fiddly job.
Aug 23, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
