Question about Honeywell HWM-450 4 Gallon Humidifier
Need Replacement Tank for HWM-450 humidifier not under warranty
  • 114 Answers
The website that you can go to to order is www.appliancefactoryparts.com. type in your model number, clickon a picture once it loads and then scroll down the page until you see water tanks. right now the price is 39.99
Posted on Aug 21, 2009
Why does my Honeywell HMW450 humidifier keep shutting off?
Here are a few things to check:
-make sure the heating element is clean. If there is a thick layer of scale (mineral deposit), then the unit will not turn on.
-there are magnets on the water reservoir that allow the unit to turn on. If these magnets are not lined up properly, then the unit thinks there is no tank, and thus, not turn on.
-turn the humidity up past your target point. The humidity near the unit could be a lot higher than the rest of the room, causing it to shut off prematurely.
Hope this helps!
Apr 29, 2012 | Honeywell HWM-450 4 Gallon Humidifier
Need replacement o-ring for water tank cap
This is a posting from someone other than myself...however, it presented a good solution.
A solution to the problem with the fill cap failing/leaking. It was/is not the cap, it's the gasket/grommet/o-ring. Remember "THE MAGIC BULLET", well the gasket, that's where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
SEE EBAY: NEW AUTHENTIC MAGIC BULLET 4 REPLACEMENT GASKETS SEALS
Recommended:
Yes
Amount Paid (US$): 45.00
Battery Life: N/A
Noise Level: Almost noiseless
Dec 24, 2010 | Honeywell HWM-450 4 Gallon Humidifier
Honeywell HWM 450
I found a solution to our problem with the fill cap failing/leaking. It was/is not the cap, it’s the gasket/grommet/o-ring. Remember “THE MAGIC BULLET”, well the gasket, that’s where you tighten the top to the bottom, some are white and some are black, THEY FIT the Honeywell HWM450!!! ------- Problem solved.
Dec 31, 2009 | Honeywell HWM-450 4 Gallon Humidifier
Humdifier wont work
I'm having the same issue
Jan 18, 2009 | Honeywell HWM-260 Humidifier
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Dec 19, 2008 | Honeywell HWM-450 4 Gallon Humidifier
Water leak
there is no sealing replace the rubber band on the connection of the tank windman
Dec 30, 2005 | Honeywell Warm Mist HWM-255 Humidifier
Manual
I lost my manual as well but found this link to a pdf version in case anyone else has the same problem finding it as we did. http://www.appliancefactoryparts.com/content/pdfs/113129.pdf
Dec 18, 2005 | Honeywell Warm Mist HWM-255 Humidifier
Open Questions:
Honeywell HWM-450 4 Gallon Humidifier Logo
546 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
