Question about Symbol LS2208 Handheld
LS2208 works - Keyboard does not
I have a LS2208 wedge connected through PS2 connection to the back of a PC running Windows XP. The scanner works fine but the keyboard is not recognized by the PC at all, even though I can see that the keyboard is getting power to it because the Number Lock key is lit up.
Please advise me on how to set this up so that both the scanner and the keyboard can work simultaneously.
Thank You!
  • mike_ives Feb 25, 2009
    Thank you dbusselle!
    I actually figured it out. There is a PDF with a list of barcodes that need to be scanned depending on which configuration you are using the scanner with. I scanned the barcode indicated with the wedge/keyboard config and it worked immeditately.
    Here is a link for the Symbol LS2208 Quick Start Guide where you can print off the barcodes from a PDF.
    http://support.symbol.com/support/search...
    Thanks Again!
  • 54 Answers
Check that the wedge is good. It is basically a hybrid spltter that powers both the scanner and the keyboard.
USB keyboard?
If so, you may want to go direct to either a serial port or a USB direct connection
Posted on Feb 24, 2009
  • Dave Busselle Feb 25, 2009
    I have the scanner config sheets also. Have worked with them for a few years, but they keep changing models and types.
    glad you got it fixed
Hello I have trouble with laser ls2208 it is PS2 connection but i have only USB on PC so i buy converter ps2 to usb but after connected scanner read product but not send text to pc .
You can try scanning the Keyboard Wedge host type barcode IBM AT Notebook then rebooting your PC. If this does not work you should order a CBA-U01-S07ZAR. This is the USB cable for use with the LS2208. Zebra Technologies support solution ADC-00217 addresses this type of issue. The article was written for connecting to a laptop, but your connection is similar if you do not have a keyboard attached to the cable. This link will take you to the solution which includes the IBM AT Notebook barcode. portal motorolasolutions com Print the article and scan the barcode then reboot your PC.
Dec 11, 2014 | Symbol LS2208 Handheld
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
Oct 28, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
Reading codebars
A solution to your problem would be to use usb cable to connect the scanner to the POS system. I have had a similar issue in the past where the IBM pos system did not like the cable that the customer had and we've got around this by using usb instead.
I hope this helps you although it may not be the kind of answer that you were looking for,
Mar 24, 2009 | Symbol LS2208 Handheld
Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
Mar 14, 2009 | Symbol LS2208 Handheld
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Nov 09, 2008 | Symbol LS2208 Handheld
LS2208 keyboard Wedge only works with PC keyboard connected
one of the settings in the code book is to emulate keyboard function. turn this on and you do not need to have the keyboard plugged in
Sep 24, 2008 | Symbol LS2208 Handheld
SCANNING PROBLEMS
We are major Symbol/Motorola dealers...I can help. I don't understand your question. (By the way, by changing the cable on your keyboard wedge models, you can also use them on the USB ports. Give me a call at 1-866-306-7226, or you can also contact the Help Desk at 1-800-653-5350
Cheers.
Bill Matisz,
qdata inc.
Edmonton, AB
Mar 03, 2008 | Symbol LS2208 Handheld
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
Symbol LS2208 Handheld Logo
1,062 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
