Question about Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A
Half of upright freezer not freezing.
I have a maytag upright freezer, only 1 1/2 years old. The top shelf and door have stopped freezing. Thought it was the seal but it seals properly. I've turned up the stat but only cold air on the bottom shelves. Any idea and is this expensive to fix
  • lisabarrett May 15, 2009
    The top shelf of my upright freezer is not freezing. The rest of the shelves seem seem to be but I'm not sure if they are or just not thawed yet.
Oceti
  • 51 Answers
SOURCE: Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Posted on Dec 07, 2007
jumptrout51
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
SOURCE: maytag upright freezer model MQU1556AEW
I have the same issue with no fan, found fan "shaft" had become loose inside motor and fan blade pinching wire between fan blade and motor bracket, Needs new motor and fan blade, fan blade is damaged from hitting bracket, I did contact maytag warranty and explained that freezer only worked six months and has been sitting but they had no offer for help,
Posted on Sep 16, 2009
SOURCE: Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Posted on Feb 15, 2010
  • 4793 Answers
SOURCE: I have a maytag upright freezer. It is on the
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Posted on Mar 03, 2010
Things don't freeze on the top shelf right hand side of the door. Also have small amount of water that drips after freezer is opened. This is a manual defrost freezer 20 cu foot freezer
I would suspect the door seal is not making contact or has some defect in it. And that defect is probably in the top right corner of the door. If you have a thermomiter, wait until the compressor kicks in and then slowly run it around the door seal. There should be some area that is colder than the rest. If I am right, then you will need to replace the seal.
Jun 15, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
CAN YOU TELL ME HOW TO CHANGE THE DOOR SEAL PLEASE ON UPRIGHT FREEZER?
There are a bunch of 1/4 screws around the door inside underneath the gasket. Make sure you unload all the food from the door. Unscrew the upper half first, remove half of old one and install a new one. Then the other half. Tip: Don't unscrew the screws all the way. Just loosen them up.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 20, 2011 | Maytag Freezer 20 cu. ft. Upright Freezer
Top shelf not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 27, 2010 | Freezers
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Freezer - top shelf frosted over -- poor cooling through rest of freezer
Hi yadak,
Happy to help.
You may need a new door seal.
But they are not easy to put on properly
and I would not recommend spending a lot of money on a ten year old freezer!
the new ones are much more energy efficient and will save you a lot of money!
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A Logo
294 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
