Question about Ricoh Caplio R5 Digital Camera
1GB Memory Card
I have Ricoh R5 Digital Camera,when i take the photos and it seems to get to 8 pictures and says "writing to card",then ERROR appears 00-00-00 26-03-08.Can you help with a solution.The memory card has been fine for over a year so the make"Kingston" cannot be the problem.This should hold a lot more pictures than this shouldn`t it?
  • manda77 Apr 21, 2009
    I have the same problem and a different card doesn't fix it.
I switched Power on and Power off and again Power on an power off and oeps the camera did work again.
Posted on Apr 09, 2012
Try another card - 1Gb is like $10-$15 these days.
Posted on Mar 17, 2009
Where can I obtain a driver for Caplio R5 Camera Windows 7
You don't need a driver. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 02, 2012 | Ricoh Caplio R5 Digital Camera
I just accidently deleted a film from my Ricoh Caplio r5 camera, any chance i can have it back..? S x
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this file recovery software called asoftech data recovery
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
Install and open the photo recovery software, select the memory card, and click 'Next' button.
Jul 13, 2011 | Ricoh Caplio R5 Digital Camera
I borrowed a Caplio R5 camera, have taken some super pics, but couldn't download onto computer. So took the memory stick to Boots and their developer couldn't find the photos. Put the memory stick...
The Photo's are currently stored on the cameras internal memory, you'll need to transfer them to the card using the camera's menu options.
Failing that, plug the camera into your PC and switch on, a box should appear asking you which programme would you like to access the new device with.
Select the folder option, then click on and open any folders therein, one will be the camera memory the other the card memory.
Jul 04, 2011 | Ricoh Caplio R5 Digital Camera
How do I download to my hard drive?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 21, 2011 | Ricoh Caplio R5 Digital Camera
Camera caplio r5 i cant take any more photos because it is coming up car is write protected
Remove the memory card and move the little switch to unprotect, try again.
Apr 24, 2010 | Ricoh Caplio R4 Digital Camera
Card is write protected.
To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Nov 24, 2009 | Ricoh Caplio R5 Digital Camera
"error write" memory card XD M 1Gb
You may want to check Fuji's website and make sure that the 1gb card is compatible for the camera. You may need to have the firmware in the camera upgraded to support storage that large.
Feb 07, 2009 | Olympus Camedia C-350 Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Panasonic FX3 Memory error: only takes 3 pictures
I would recommend formatting your existing disk. If that doesn't cure your problem then replacing the disk should do.
Hope this helps,
erch.
Mar 15, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
Ricoh Caplio R5 Digital camera
Not many but a FUJIFILM 1 gb card will do the trick
Nov 26, 2007 | Ricoh Caplio R5 Digital Camera
Ricoh Caplio R5 Digital Camera Logo
164 people viewed this question
Top Ricoh Cameras Experts
Cleverer2
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
