Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Insinkerator Disposal Badger 5 Plus 5 Leaking From Top
This unit has a few years on it and recently began leaking. The leak is coming from the location shown here:
http://img178.imageshack.us/img178/562/badger5.jpg
I do see alot of posts about leaking from the bottom, but that isn't the case with this unit. The upper part with the name of the unit appears to be a decorative shroud of sorts, it moves around some and the leak is seeping from under it and running down. I've looked inside from the sink end and nothing appears unusual there.
It does not leak when I'm running water through it and not running the disposal, it only leaks when the disposal is running also.
I've also looked at where it mates with the sink and that does not appear to be the source, but I'm going to tighten it a bit and see what happens anyway.
  • 137 Answers
I believe that schroud is a noise insulator, it is installed aroung the grinding chamber to minimize the grinding noise, the part below that is the motor.
Now for the leak, if it were me I would remove the disposer from the sink, really not a big deal and see if I could remove the sound insulator, I would presume then taht you would see signs of where the leak is eminating from.
Seeing that the disposer doesnt leak when it 's not running I think it can be repaired at home using a two part epoxy patching material used for marine pourposes.
It's worth a try, the worst thing that can happen is that you are out a little of your time.
Posted on Feb 24, 2009
My Badger 5 InsinkErator garbage disposal leaks out of the seam about midway down the unit. I don't know how old it is as it came with the house I bought 3.5 years ago. Is it something I can fix?
if the inner seal is leaking -- it is best just to go and buy a new garbage disposal and install it.
normally when the seals start to go bad in the units it does start to effect other parts of the disposal,, and it is kinda a domino effect.
c...
Feb 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just noticed that my insinkerator Badger 5-75
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
heatman101
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is leaking from the base of the Badger 1. Appears to be coming out of the reset switch. Can i repair this?
There's only one repairable thing on a garbage dispostal, and that is where the pipe (drain) comes out. If it is leaking from there, it can be fixed. If not, it means the housing is cracked and you need a new one. PS don't turn the disposal on since it's leaking from the electrical connection!
Feb 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 InSinkErator and it is leaking, not from the bottom but from a leak hole in the top side middle of the unit. I can see the water coming out of the hole. Can it be plugged? the unit works...
There should be no leaking to the outside of the motor. If there is a weep hole, it would indicate there is a seal problem between the cutter blade shaft and the motor. Contact ace hardware and see if theycan give you a little more information on this unit.
Jan 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking out of bottom of unit, near reset
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking
first check and make sure that the water is not leaking from the hose connection to the dishwasher or the drain fitting itself. If neither of these is the problem and it is definetly leaking from the housing then replace. I recommend the Badger series disposal with a 5 or 7 tear warranty I have installed them for years and never had a single problem.
Jul 31, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
May 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,999 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
