Trying to connect my laptop to our savin printer for the first ti
Trying to conect my laptop to the printer for the first time
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the copier?
  • Anonymous May 11, 2010
    Cool, good for you! How about letting us know what type of printer, and what type of connection you are trying to make
    Sergeant:
  • 199 Answers
I think you can easily connect with direct lan cable
Posted on Feb 27, 2009
How do i reset a fusing unit counter on a CLP22
Hi. First of all did you have a code to tell you to replace the unit? I would like you to put the old unit back in and see if it lets you restart your printer. If it comes back up you have a problem with the new fuser you received. Take a few seconds to compare the unit and make sure all looks the same. If it's a remanufactured some times little things like tabs and the such get bent or broken. It should reset the counter when you set the new one was replaced. Hope this helped. I do get a little wordy at times
Feb 04, 2015 | Savin GENUINE RICOH FUSER UNIT (402451)...
Black will not print on a savin clp22
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Oct 16, 2013 | Savin GENUINE RICOH FUSER UNIT (402451)...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
I have a Savin 8045e connected with USB and can't scan
its needs to be connected via network to scan and not usb i believe
Apr 12, 2010 | Savin 8035e Copier
Epson printer not conecting with computer
there might be a connection issue here. if it is connected using a usb cable, check if your printer is talking to the computer, that means you will check if the computer can recognize the printer when connected using a cable,
i hope you state the os of your computer, anyways,
if XP click start--control panel--classic view--system--hardware--device manager--universal serial bus controller--look for usb printing support
(if you found it, connection is good)
if it is not there, unplug and replug the usb and try again, try another port on the computer, if still not, try another usb cable, if both usb are not recognized, it might be the port of the printer or computer, ti=o isolate that, try another computer if thats possible.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Feb 18, 2010 | Epson Stylus Photo 2100 InkJet Printer
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
PhotoSamrt C3180 won't print from network laptop.
Hi there
I have had tis problem quite a few times with manay networked printers disable your firewall on the pc which the printer is physically connected then try to search for the printer from your laptop see if that does the trick for you
Hope you find this helpfull if you do please spend an minute leaving feedback
Regards Al "alstech"
May 24, 2009 | HP Photosmart C3180 All-In-One InkJet...
Scanner module needed for Savin 9935DP
Hi There,
Go to this link...it is the same model, except listed as a Gestetner.
http://www.nrgcss.com/drivers/Page3.asp?Brand=gest&Vw=&Fltr=0&Ky=578808089&Usr=&Cat=3&Mdl=11&Drv=3127
Good Luck.
Steve C.
PS... Please Rate Me.
Nov 20, 2008 | Savin 9935DP Laser Printer
63 people viewed this question
jasbo
jasbo
