Question about RCA HD52W59 HDTV Projection Television
I have an RCA HD50LPW62A television set....We recently had a power outage. The green power button is on and will not go off. We have tried disconnecting the TV and plugging it back in again, to no avail. The green power button just continuously stays on, but there is no picture, no sound - The TV looks like it's off. We are unable to turn the power button off, either via the remote or by pushing the actual button on the front of the TV. Any ideas? We've changed the bulb in the past, and have also had a new color wheel installed - This problem is totally different than either of those...I'm about ready to throw this TV out the window!
  • laurieb58 Feb 25, 2009
    Is this something that can be fixed by a repairman, though?
    Also, do you think it could have been related to the power outage?
    Thank you....
  • markbe13 Apr 15, 2009
    Green power button continuously on, screen is black. Cannot turn on or off. Have unplugged several times, to no avail. Technician said it may be a power board that would cost $550-$600 to for part and installation. Basically told me the TV was now a giant paperweight.
    Any ideas?
    Problem Solver:
  • 18 Answers
Usually has a bunch of bad capacitors in the power supply. they may have the top puffed up. these are in the power supply where there are high voltages. not an easy repair
Posted on Feb 25, 2009
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
I have a rca hd50lpw62a and its slow to turn on and dim when on.
If your tv is around 2-4 yrs or used 6000-8000 hrs,never replaced the lamp before it could be time to replace it.If you hear strange noises like buzzing or humming noises it could be the color wheel which is a little disc that has a gamma of colors and spins at high rpms.When the light of the lamp goes through it creates the colors on your tv.The other most common failure is the board that powers the lamp,which is called the ballast.When its bad it will make a clicking sound or like wanting to turn on.Your part # for the lamp is 265866 and you can find it here: http://www.discount-merchant.com/RCA-265866-265919-269343-271326-270414-Lamp-p/rca-lamp-265866-26591-269343-r.htm Good luck and blessing for your house!
Feb 10, 2010 | Televison & Video
Wont turn on after power outage
there is a power supply board that goes bad in this set. Good luck
Aug 15, 2009 | RCA P61927 61" Rear Projection Television
RCA 52'' projection TV: will not turn on
Try unplugging the set for a full minute, then plug it back in and try again.
Sometimes this will reboot a glitched up computer.
Otherwise you will need the assistance of a professional.
www.mcveyelectronics.com
May 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Color wheel quit
You can get help at;
http://servicemanuals.vstore.ca/
They will charge for manuals but they also give on-line tech support free!
Feb 07, 2009 | RCA HD61LPW165 61" Projection HDTV
Green light continues to flicker, TV will not turn on or off.
Unplug it for 30 minutes. Then try again.
Let me know and I'll check the service manual. I've got a 65511.
Feb 01, 2009 | Mitsubishi WS-65809 65" Rear Projection...
RCA P52721LV
In the back where the power cord comes into the unit there is a small fuse there, replace and try.......
Sep 21, 2008 | RCA P46924 46" Rear Projection Television
RCA hd50lpw62a green power light comes on blinks and goes off tv never comes on.
That set is famous for faulty flybacks. But its an easy inexspensive fix that takes under 30 mintues to do. You can get a new flyback at the following link for around 50 dollars and they provide free online tech support so you can do the repair yourself. You would need flyback number 259296 heres the link.
May 15, 2008 | RCA Televison & Video
Rca d52w20
if you had a power surge from the outage it could be anything. disconnect from the house power and try again in an hour.
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv dont come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | RCA D34W135D 34 in. TV/DVD Combo
RCA HD52W59 HDTV Projection Television Logo
197 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
