Question about True T-49 Side by Side Refrigerator Commercial
True t-49 compresser not running at all
I came this morning to find my t-49 very warm and the compressor not running at all i opened the cover plate and checked all the wires every thing seems fine if you keep it plugged in the fans inside work so i am guessing it is not an electric problem what else should i be looking at or should i be looking at a new complressor
  • True Master
  • 3,361 Answers
Is the compressor fan motor running?
If so, replace the capacitor on the compressor.
If no.
Replace the thermostat.
Posted on Mar 05, 2009
  • frank711158 Mar 28, 2011
    yes,helpful, but can you burn-out a compressor? We laft the door open for an extended leight of time and now the compressor doesn't turn-on. I don't know how to began to change or check thermostat,help please.
T-49 warm in the morniing, but then works fine all day
Sounds like you are letting the refrigerator sit in an unheated space at night. Those refrigerators have minimum temperature ratings as well as maximum temps. True Mfg. Can be more specific but I say not under 60deg F. Good luck hope this helps.
Apr 09, 2014 | True T-49 Side by Side Refrigerator...
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
True 49f goes into defrost mode the contact opens for the compressor but the compressor keeps running
in many cases, these units have relays or contactors where the contact points actually weld together. this causes the unit to stay running even though power to the coil has been stopped. I'd start looking there first. don't over look the possibility that someone could have mistakenly miswired the unit.
Aug 19, 2010 | True 49 cu. ft. / 1388 liter Commercial...
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Mar 14, 2009 | True 49 cu. ft. / 1388 liter Commercial...
I have a 2 door reach in true freezer which is now just keeping a steady 5 degrees about temp, should be 0 -10, fans, compressor, fans evap are all runing okay, the coils were clean, so what could the...
If its getting warmer or more humid where you are this is probably a sign of needing to clean your outer coils. Remove the panel covering the compressor and check the condition of the coils. Clean with a nylon brush or wire brush. Or blow out with compressed air.
If the outer coils look OK see if they feel warm up and down the sides. If they don't you may have a defrost problem. If they are warm recheck them in 30 minutes if still warm or warmer and no one has opened the door check the lite inside, and the fan inside (it will only run with door closed). Hit the switch and see if lite goes out and make sure the switch is being activated with the door closed. And check the door seals any vinyl cracked on them they need replacing but can be warped sometimes letting in warm air (usually a sign of frost inside the door or water leaking out but not always).
It could be low on refrigerant or an inefficient compressor but not likely as much as these other items are.
The last thing is the thermometer could be reading wrong or out of calibration. Is it Electronic? Yes - Then its most likely one of the other problem before. If its mechanical (bi-metal) get another thermometer you trust or a new one and check it before you trust it. 2 of them telling you its 5'f then Id believe it other wise one or both of them are wrong.
Mar 12, 2009 | True T-49 Side by Side Refrigerator...
True 2 door reach in freezer
If the outer coils look ok see if they feel warm up and down the sides. If they dont you may have a defrost problem. If they are warm recheck them in 30 minutes if still warm or warmer and no one has opened the door check the lite inside, and the fan inside (it will only run with door closed). Hit the switch and see if lite goes out and make sure the switch is being activated whith the door closed.
It could be low on refrigerant or an inefficent compressor but not laikey as much as these other items are.
True t-49 refrigerator
Yes it can. You would have to call a service company to recover the refrigerant, remove the oil in the compressor. They would then replace the oil as well as the refrigerant. The metering device would also need to be changed, along with the thermostat.
Aug 17, 2008 | True T-49 Side by Side Refrigerator...
T-49 delivery - set-up
Make sure that the service valves are open. After you have checked that, hook up your refrigeration gauges and verify that you have not lost all of your refrigerant. Please do this and let me know if you need any further guidance.
Aug 04, 2008 | True T-49 Side by Side Refrigerator...
T-49 Relay
hi thanks for the question you gan get the relay at kemet electronics thanks the appliance doc
Jul 30, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
374 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
