Question about Regal Ware 58001R
Regal Ware coffee maker 58001R not brewing
Coffee percolator is filled with water, plugged in, and turned on, but the unit is not percolating at all. I love this thing--what can I do to fix it?
  • Wayne Lowdon Feb 07, 2012
    I tried posting a solution, but didn't work.
    I have the same problem, but mine is not the element, but the high limit thermostat.
    You may also have a problem with the high limit theremostat, or possibly continutiy in the cord set, or swtich.
  • 137 Answers
I'm afraid the heating element is burned out.
Posted on Feb 24, 2009
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Tip
How to disassemble & brew coffee using a Corning Ware P-146 or P-149 Coffee pot
Click on the photo below to read the original manufacturer's instructions on how to take apart & brew coffee using either the Corning Ware P-146 or P-149 coffee percolator. These early models are unique due to the outer pot lid threading directly onto the stainless steel coffee basket.
on Apr 09, 2015 | Home
Need replacement cord for corning ware E1210 percolator
Since the Corning Ware electric percolators are no longer made, you can find good used replacement cords and other parts on eBay. That's where I go to complete all my pots.
Oct 09, 2012 | Hamilton Beach Proctor-Silex Simply Coffee...
Why won't our poly perk percolator shut off?
I just bought a Poly Perk percolator from a thrift store. If yours is the same, it's a vintage plastic, electric percolator. I found your question while searching for directions for mine. My percolator does'nt shut off either. It just continues running. I don't know if it has a shut off, but I figure I'll just unplug mine for now since it made really good coffee. If it's supposed to shut off, I suspect we're both stuck with few options. I hope you find your solution though.
Jan 18, 2012 | Regal Coffee Makers & Espresso Machines
Coffee too weak
Probably a bad thermal switch. My wife had the same problem with hers and I recently fixed it.
What is the temperature of the coffee when if finishes brewing? It should be around 190 degrees F. If it is cooler than that it indicates the switch is turning the heater down too soon. This means the pot doesn't circulate hot enough water through the grounds and the coffee ends up weak.
Replacement switches are available from
http://www.goodmans.net although the one I got wasn't an exact fit I made it work.
Dec 05, 2009 | Toastmaster Farberware Percolator
How do I make coffee in the corning ware coffee pot? It is the top of the stove maker and does not have any electrical cord.
This is a stove top percolator and you can use the great directions here:
http://www.talkaboutcoffee.com/how-to-make-coffee-in-a-percolator.html
Nov 19, 2009 | CorningWare Crock Pots & Slow Cookers
Weak coffee is the result of brew
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 17, 2009 | Regal Ware 58001R
Since it is "brand new out of the box" check for plastic burs (pieces of plastic improperly hanging around
openings along flow of water) throughout unit, and use more coffee than recommended for your taste of
what a good cup of coffee should taste like, since that varies from individual to individual. If you are using
packets, try using TWO. Experiment, Experiment...........
Apr 17, 2009 | Regal Ware 15-0264 Polished Aluminum...
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
415 people viewed this question
Top Regal Ware Coffee Makers & Espresso Machines Experts
Tom Chichester
ray gallant
Are you a Regal Ware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
