Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
I have a Singer Futura CE-250 and when I am embroidering and have to change thread color I often get an 88 error. There is nothing in the manual that tells me what this error code is. Can anyone help with this?
  • 23 Answers
Try Gezina Sewing machine I find they are very helpfull.
(012) 335 0636
Posted on Feb 27, 2009
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
Sews normal fine, when I try to embroider it eats the material, the threads go down inside the machine. I use a stabilzer on the back and make sure you can thump it, still eats the materials. Changed...
try changing dogfeet. take off embroider unit look below needle under machine and there is a wheel turn it the other way and try this. If you still can't get it to work contact me at nyreka@elmore.rr.com and I will try to help further.
Dec 03, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer FUTURA CE-250 beeping at startup.
you have a bit of cotton blocking a sensor or lever. normally the one that tells you ran out of cotton.
Oct 03, 2009 | Sewing Machines
Hi, I'm trying to embroider using my Singer Futura CE-100. After it starts to embroider, it will either bunch up bobbin side or the machine will beep, and the computer says to turn it off, remove hoop,...
could be a threading problem. on the top of the machine, where you go under the plate, pull the thread back and forth like you are flossing. you should feel the thread snap around the 2 wheels, then continue threading. hope it helps
Aug 15, 2008 | Singer CE-100 Futura Computerized Sewing...
Can't seem to embroider
brothers frame is much smaller I think 4 x 4. I have futura 200. found this to happen at first but now now. Make sure when threading that you floss the thread through the top part, it has plastic over it. The thread must fit properly in this part. (flossing means to run back and forth a couple of times holding thread tightly). Also, hold the 2 thread ends when you first start to embroider. Hope this helps
Apr 12, 2008 | Singer CE-200 Quantum Futura Computerized...
Bobbin Thread
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
My machine is giving me an error 88 and keeps flashing fast when I turn it on.
I had that problem when the machine was not threaded correctly. I now floss the thread back and forth through the tension area everty time I thread the machine, to make sure the thread is in the right place.
Feb 15, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
702 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
