Question about Avaya Partner 18D Display Phone (315807BA)
Partner 18D not ringing, just beeping
When calls come in, the phone beeps and does not ring. I would like it to ring.
The phone is forwarded.
At that phone, press feature 11, XX, XX
Where the XX's are is that extension number. So if it was extension 12:
Feature 11, 12, 12
Posted on Feb 26, 2009
When I call another extension the phone I am calling doesn't start ringing until I hang my phone up, how do I fix this?
I would check the called extensions ringing pattern and see if it is set to delayed or no ring.
Oct 17, 2014 | Avaya Lands Phones
Avaya partner acs
Are these call from the outside? If so, it sounds like the Night Service is turned on. If not and these are extension calls then the Do Not Disturb is probably on.
Jul 23, 2014 | Avaya Eurostyle 18D Corded Phone
On a Lucent Partner 18D system I have to press a line to answer a call. How can I program to answer at pick-up?
My guess is that your phone is not programmed to ring immediately. A Partner system doesn't have the ability to make you press a line to answer a call if it's already ringing. IIRC you can press FEATURE and dial 00 and look at the line buttons. If they're not lit steady green, you don't have immediate ring.
Ringing assignments are programmed from Centralized programming at extension 10 or 11. The lines will be lit steady green for immediate, slow blink for delayed, or fast blink for no ring. Consult your system manual for how to get into Centralized programming and program your extension.
Carl
Feb 28, 2011 | Lands Phones
Avaya Partner System. 18D Phone. Suddenly, I get a beep when an incoming call hits the system. No idea why it started. How do I get rid of it?
Is the time and date correct on your phones?
Usually this means that the system has lost programming, and when a call rings in, the voicemail picks up. The system will need to be reprogrammed from scratch. The voicemail boxes and messages will still be there, but the phon system doesnt know where the voicemail is until its programmed.
Dec 15, 2009 | Avaya Corded Phone avaparp18d
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Apr 13, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
Ringer for Lucent Partner18D
Are you trying to change if it rings or how it sounds when it rings?
The phone you have (Partner 18D) can be used on several different Avaya phone systems that all program differently. To change when it rings, this would need to done in the system programming (not the phone) All the manuals are avaialble on Avaya's web site but you need to know which system you have before you can start searching. www.avaya.com
Nov 26, 2007 | Lands Phones
Lands Phones Logo
543 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
