Question about ViewSonic N1800TV 18 in. LCD Television
How do I replace the backlight in a ViewSonic N1800TV?
If I look at the monitor from a certain angle, I can see that the menu still pops up. So I think the screen is fine. The screen is just VERY dark. Is changing the backlight something I can do on my own without spending a fortune on taking it to the dealer?
  • 362 Answers
Hi Jake.
You most likely have a bad backlight inverter, there is a small chance it could be a power supply issue but I doubt it.
Replacing the inverter should be straight forward and easy but working with high voltage electronics can be very dangerous, I must tell you that it should be repaired be a trained professional but if you decide to do it yourself I will walk you through it.
You can buy the inverter at www.shopjimmy.com. When the part comes in get back with me and we can proceed in a chat from there.
In the meantime please rate me a FixYa.
Lone99star
Posted on Feb 24, 2009
Our viewsonic monitor is VX2235WM-3 the
The short answer is no, becuase by time you pay the $50 for the backlight, and $75/hour for the tech to fix it, you can buy another 22inch for the same price and have a 5 year warrinty.
Sorry,
Have a nice day
Aug 29, 2011 | ViewSonic VX2235WM Monitor
Re: Problems with Viewsonic VE710b
If it's too dark to see the menu to adjust the brightness, it's a bad backlight - send it back!
Sep 10, 2007 | ViewSonic VE710b 17" Flat Panel LCD...
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
Viewsonic vp2000s LCD computer monitor - no image displayed; possible backlight outage.
It is possible that the backlight has quit working. Use a flashlight, held at an angle to the display, to see if there is a faint image visible. If so, then have backlight repaired. Otherwise, try a different input / cable.
Aug 17, 2010 | ViewSonic VP2000s 20.1" Flat Panel LCD...
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Extremely Dim/Dark ViewSonic Monitor
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | ViewSonic VX2235wm LCD Monitor
ViewSonic Main menu pop up all the time
Replace the button switch. That switch may worn out, Kindly give feedback after problem get solved
Aug 23, 2009 | ViewSonic VA1930WM LCD Monitor
My viewsonic monitor is fluxuating pinkish to white to pinkish
When LCD monitors start turning pink that is an indication that the backlight tubes are failing. Check the date on your monitor most Viewsonic LCD monitors have a 3 year warranty and yours is probably still covered. If it is not then you may want to look for a replacement unit. You can replace the backlight tubes but if you are not a tech it is probably not going to be easy for you to do. If you have questions email me and I will try to help.
Buddy
Corporate Computer
www.ccl-la.com
Aug 15, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX900 LCD Monitor No Display.Bcklt and Screen Menu Work
It looks like you have to replace mainboard (it doesn't take input signals)
Mar 26, 2017 | ViewSonic VX910 19" LCD Monitor
Dismanteling monitor/replacing backlight
http://www.eserviceinfo.com/downloadsm/6598/jean_ve710s-2.html
Go to bottom of the page to download the PDF . It has complete instruction and pictures
Jan 07, 2008 | ViewSonic VA721 17" LCD Monitor
ViewSonic N1800TV 18 in. LCD Television Logo
177 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
