Question about Memorex MP3225 Cassette/CD Boombox
CD lid won't stay closed because retaining clip doesn't grip. Where do I take it to be fixed?
  • Anonymous Mar 09, 2009
    Same problem. I lifted the handle and put a wood shim at each edge to hold it closed. Cumbersome, but it works...
    I haven't yet been able to find a parts source.
The sun visor will not stay up on my 1998 nisson altama
Most of the sin visors has a small screw near to the fixed hinge. that is to tighten up the tension to flip it open and closed. another thing to do is tightening up the grip of the clip by adding some insulation tape to the inside. a quick fix
Feb 26, 2015 | 1998 Nissan Altima
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
Model TR810 - pan jumps around during kneading cycle (1.5lb setting). Won't stay engaged in lugs. All the parts look normal; nothing bent, corroded or twisted, etc.
Bread pan pops out
reach in with your fingers and bend the two little clips out a little until they grip your pan snugly. Start with 1/4 " and try that. If it doesn't feel snug go another 1/4 inch.... and so on....
May 10, 2011 | Kitchen Appliances - Others
Doesn't start after filling with water - model 110.15962401
check the lid switch,your lid switch is under the top console,open the lid and close it a few times you should hear a clicking sound,open the lid and stick your hands in the back above the tub,there's two clips one on each side that holds the top console down,or you can use a putty knife and stick it under the console and pop the clips,you'll see the lid switch on the left side,part number 8318084 and it's around 20 dollars.
May 09, 2011 | Kitchen Ranges
I found my broken lid switch and its two plastice pieces i am not sure how to put it back together and fix it. Or can i buy a new one and then install it? Also i dont know how to take the top off too look...
I believe you're referring to the lid safety switch. Do not operate your machine without this safety switch! The switch / wiring harness are not very hard to install... here's how-
---UNPLUG THE WASHER FROM THE ELECTRICAL OUTLET---
1. Remove console, depending on vintage, there should be a couple of screws that will allow you to rotate the console up and back.
2. Remove 2 gold clips at rear of top. These clips are the only thing that retain the top / lid / cabinet
3. Unplug lid switch harness (small white connector at rear of top)
4. Rotate the cabinet up a few inches at the rear and pull it straight off. The top / lid / cabinet will come off as a single unit. The entire lid switch and harness are connected under the top w/ a couple of screws and a few spring retainers.
5. Buy replacement parts at a local appliance repair shop, including a new striker (the part that pushes the switch down when you close the lid).
6. Reinstall everything reverse from above. When you rotate the cabinet back on, make sure you have the front edge under the base channel and push inward on the rear corners to engage the cabinet on the rear base tabs.
Good luck.
Apr 24, 2011 | Kenmore 24972 Top Load Washer
The washing machine (Kenmore 80 Series) runs but doesn';t drain at the end or spin. We think it's a lid switch perhaps? Where is it located though and do you possibly have maybe a diagram to look at? Thank...
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Replace the lid switch to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 01, 2011 | Washing Machines
Do you lock the lid while cooking?
make sure u DO NOT lock the clips while cooking, its not a pressure cooker. if you lock the lid the heat and pressure from whatever you are cooking causes an air-tight seal and the lid will shatter or the ceramic pot it self will crack...
Nov 29, 2010 | Hamilton Beach Set & Forget Stay or Go...
Durabrand model cd-1493...cd won't play
A friend of mine has one of these, and the same thing happened. Toss in a CD, and the unit reads it, but doesn't play it. Looking at the CD components, all appears to be well, and I was even able to trick the unit into turning on using a paper clip to hold down the "lid closed" switch.
What I found the issue to be was with the lack of downward or clamping pressure the CD was getting with the lid closed. If you notice, with the lid open, there is a round part that "floats" and serves two purposes...one is to align the CD and keep it steady, and the other is to grip it, as the CD's do not snap into the lower centering piece, but rather just sit on it.
I solved the problem by placing a rubber o-ring on it, The one I used is about 1/16" (1mm +/-) and about 1 inch (25mm) diameter. I used some rubber cement to attach it to the top piece. I'm not sure how long this will hold, but it's worth a shot. I figure keeping a CD in the tray will help keep the ring in place as well.
Nov 27, 2009 | Durabrand CD Player with Cassette...
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
Memorex MP3225 Cassette/CD Boombox Logo
254 people viewed this question
Top Memorex Audio Players & Recorders Experts
Greg Cann
Greg Cann
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
