Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell 5000 Dimension starting issue
I have a dell dimension 5000 and lately if I leave it on for some time it sometimes turns itself off, or if I have the computer on and then shutdown and then try to restart it flashes orange on the start button and does not start, Then next day it will start normally and then same will happen again after hutdown
I have tried cleaning fan etc. This now seems as though it is not running! But issue started before this.
  • 51 Answers
You need to change your power save options. Right click on the desktop, click properties, click tab screensaver click on power tab. set the desired power save functions. hope this helps
Posted on Feb 24, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Dimension begins to boot then sits there as if asleep
It sounds like it's probably the power supply. Computers require more power to boot up than they do to keep running, so if it's fine once it gets going, the power supply may just be dying. If you have a multimeter and know what you're doing, you can test the power supply connectors to see if any of them (especially the ones leading to the motherboard) are not giving the proper voltages.
How old is the computer?
May 27, 2010 | Dell Dimension 9200 PC Desktop
When I switched on my Dell computer - bright blue
this error usually is for hard drive issue. if an operating system reinstallation wont work, a hard drive replacement should resolve this problem.
May 26, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
MAXIMIM Ram You Can Put In A Dell Dimension 5000?
Your PC can support upto 4GB of RAM incase you are using vista or Windows 7 and if you are using win XP (32 bit) then only 3 GB is supported 1GB shall standby and also make sure that they are not more than 533 HHz
Kindly rate this solution
Thanks And Regards
Feb 24, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension Shut Down
Hi
You query suggest you have Dell Dimension 3000. Dell Dimension 3000 is a desktop PC and does not have a battery backup by itself.
I am assuming the battery backup you are referring to is a UPS (Uninterruptible Power Supply). If this is correct then by your description of the issues, the UPS may be faulty (indicated by the Red light and beeping).
Disconnect the computer's power cord from the UPS and connect it to a wall power outlet to confirm or rule out the UPS as the offending device.
If this does not help reply with more info
Mike
Aug 15, 2008 | Dell Dimension 3000® Pentium® 4...
try safe mode f8 and go into msconfig and uncheak startup stuff ok
Jan 21, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 5100 (D51L1) PC Desktop Logo
140 people viewed this question
Alun Cox
