Question about Maytag SkyBox MBV1976A Beverage Dispenser
Compressor or something else???
My Skybox has stopped cooling. You hear the compressor try to come on. It hums then shuts off. Hums then shuts off. Is my compressor locked up or what else might be the problem?? Please email me at gfisher73@gmail.com.
Thank you!!
    Problem Solver:
  • 4 Answers
Whirlpool 4387835 relay will fix this
Posted on Mar 10, 2009
I have a Goodman a/c unit. Fan stopped shut off
replace the motor the bearing has seized up.
Aug 27, 2014 | Heating & Cooling
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
Mar 04, 2014 | Bush Freezers
I have a CH 8 gal compressor that won't run. When you turn it on it just hums for a couple of seconds then stops. You hear a click and then your able to turn it on again but it still just hums
Remove the air out line and the motor. Try to turn the motor and the compressor by hand. You have a seized bearing somewhere. Bearings are available at any power transmission shop for a few dollars.
Feb 04, 2012 | Campbell Hausfeld Air Tools & Compressors
Comoressor hums then stops. munal defrost
sounds like the compressor is trying to start.Shut it off and let the compressor cool then try again
Sep 14, 2010 | Avanti Freezers
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Dec 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Compressor hums and shuts off
This sounds very much like a compressor failure. unplug the refrigerator and check the condenser for cleanliness. After cleaning the condenser and allowing the compressor to cool, plug it back in and listen for the same sounds. If the compressor was overheated it should restart after it cools. If it does not restart the compressor could be seized. Check the compressor warranty against the age of the refrigerator.
May 19, 2008 | Kenmore 72912 / 72914 / 72919 Bottom...
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
200 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
