Question about Intel D101GGC Motherboard
RAM hello sir, i used 512 ram and my mother board model is D101GGC(INTEL) i want to buy another 1 gb ram .so which type of ram is suitable for this. that means ddr ddr1,ddr2 plzzzz it 's urgent
  • bsevinc May 11, 2010
    It depends on the ram that you have right now. If you have two different type of rams most likely it wont work. If you can't determine what type of ram, I would take it to the store and tell them you need a 1G ram that will work with one in your hand. If you are ordering online you have to find out what your current RAM is. ddr, ddr1, etc...
    President:
  • 1,073 Answers
Hi subbareddy!
Your mobo supports DDR SDRAM memo stucks, and the max of supported memory is 2GB.
Here is all info and drivers for your MoBo my friend
http://www.intel.com/products/motherboard/D101GGC/index.htm
Good luck
Please take a moment and rate my help for you
Nic
Posted on Feb 24, 2009
  • Nicolas
    Nicolas Feb 24, 2009
    Wasent that the info you need?
    Well well, thank you for the rating anyway M8
    And good luck with your memosticks
    Nic
    Master:
  • 763 Answers
Check your previous memory if its dd1, ddr2 or dd3 and check also your motherboard's manual for this. be sure that you add the same specs of memory otherwise remove your previous memory.
thank you for using fixya
CHARCOIS
I have intel 101 Ggc Mother board and intel pentium D processor , i was using 756MB ram (512+ 256MB) RAM. But after i brought 1 GB ram and Used it instead of 256 MB Ram the system started restarting...
There is a chance that you have faulty RAM module. If computer is stable on POST (until Windows boot-up) I would suggest to use some testing tools to test that RAM with your motherboard. There is a good program called MemTest. You can find it online if you search Hirens Boot CD. Download it, burn image to disk, put 1GB RAM into motherboard, start-up PC and boot from CD. Then you'll search for Memtest program. I would suggest to leave PC for at least 6 hours for testing to find out if it's faulty or not (better to leave for 24 hours).
Aug 17, 2011 | Intel D101GGC Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Upgrade ram
hiya
this board is ddr so you will need ddr400 or pc3200 and a maximum capacity of 2gb so be carefull with 1 gb sticks as sometimes this causes system crashes
hope this helps
Regard Rik
Feb 26, 2009 | Intel D101GGC Motherboard
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
165 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
