Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon ir 2200 Error code E000064-0000
About canon photocopier ir 2200.
  • 5 more comments
  • henrisco777 Feb 24, 2009
    how do I solve error code E00064-0000.
  • Anonymous Mar 12, 2014
    Error code E000805 for ir2525i, what's it mean?
    Error code E000805 for my ir2525i, What's it mean?
  • Anonymous Mar 17, 2014
    code error canon ir 6570 full solution
  • Anonymous Mar 20, 2014
    indicating replace yellow toner
  • Anonymous Mar 22, 2014
    canon ir 2318 photocopier the problem is error code E00001-0001 E000808-000
  • Anonymous Mar 31, 2014
    e000024-0000
    Sergeant:
  • 199 Answers
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
    New Friend:
E225-003 ERROR PROBLEM
Posted on Apr 25, 2013
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
Canon ir2016 photocopy machine printer software
i want to get the Canon ir 2016j photocopy machine drivers
Oct 20, 2010 | Computers & Internet
I required Canon Photocopier IR3300 driver
Hi, try this link for your driver:
http://www.givemefile.net/drivers/_xerox_and_ifis/canon/ir-3300.html
Aug 07, 2010 | Computers & Internet
E000000-0000 on canon ir2200 photocopier how to clear? I'm having the "E000000-0000 on my Canon ir 2200 photocopier everytime i turns it on. Is there any way to clear this error?
this is tadesse E000is the main thermiistor (TH1) has poor contact or an open circuit. the termal switch (TP1) has an open circuit.the main /sub heater has an open circuit .the main power supply PCB is faulty. the DC controller PCB is faulty .you can clear starting service mode 1) press the user mode key *
2) press '2' and '8' on the keypad at the same time
3)press the user mode key * on the contrl panel
(copier, fuunction,clear,ERR
May 19, 2010 | Office Equipment & Supplies
Hi I need to connect my photocopy canon ir
you must put an ip address,on the machine ( system),and the port of the driver you must put the same ip.
Apr 04, 2010 | Canon iR 2016i Black and White Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
5,291 people viewed this question
old marine
old marine
