Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Motherboard dont do any thing
Motherboard get power but do not display anything and do not chik on the ram
  • 1 more comment
  • sherif khedr Feb 25, 2009
    NO SIR
    JUST THE PROCESSIR FAN WORK BUT THE MOTHERBOARD DO NOT CHICK ON RAM AND DO NOT MAKE ANY BEEB
    THANX
    my cpu is working
    my video output and the ram are working
  • bsevinc May 11, 2010
    Did you upgrade your RAM lately. Does it beep when it boots, or does it boot at all?
  • 203 Answers
Is your cpu working?
is the video output working?
is the ram working?
have you tried any of the components on another system?
you could have many problems with this board.
Posted on Feb 25, 2009
No ram beep comes without ram and no display
> No RAM beep comes without RAM.
That is to be expected -- when the motherboard does _NOT_ detect any properly-mounted RAM, the motherboard sounds the "no-RAM" beep.
> and no display
Correct. Without RAM, the computer cannot "paint" anything onto the video screen.
Nov 06, 2010 | Intel D845GVSR Motherboard
My Motherboard is doesnt displays. i have checked cpu, ram , power supply they all work properly. if i turn on the motherboard it doest give any beep sound and also doesnt give display. if remove the ram...
Maybe a silly question but have you downloaded the latest video codecs for your processor?
http://www.moviecodec.com/downloads/31d.html
Are you plugging in all necessary power connections on the motherboard? Does the video card have power connector on it and do you have the necessary power cord plugged into it?
Double, triple, quadruple check that your RAM, video card and your CPU are fully seated. If you still can't get things to go from there, you pretty well need access to another machine for which you can test your parts individually as something is most likely a dud.
good luck
Oct 24, 2010 | Intel D845GVFN Motherboard
I change the ram and since then even with the old ram it just dont want to boot up, it sounds as if the computer is starting but nothing is displayed on the screen its just black, like there is no...
If its a ram problem then you should not get anything out of it at all. If it generates any beep codes or anything then it probably isn't the ram.
First thing to try is reseat the cards and check the ram. You may want to go back to your original ram and see if those work. If it works on the old ram then the problem is either the new stuff being the wrong type , wrong speed, or not being seated properly. Usually its just the wrong type or speed. You may find that even though it says it is the correct thing it won't work. You get that a lot with cheaper ram brands.
Trick is to go back to a working configuration and then change one thing to rule things out.
Sep 14, 2010 | Asrock 775Dual-915GL Motherboard
Display probelm
After reading your issue,i am sure that there is problem with your motherboard.
as you cannot see anything on screen and you get power,that means your motherboard is faulty
so just get your motherboard replaced and it will be fine as before
Thanks
Jul 28, 2010 | Intel Desktop Board D845WN Motherboard
On HP Pavillion 512n - When I plug the computer in only the fans work and the light on the switch is on. There is no drive sound and nothing on display. Is it a motherboard problem or power supply problem?
first thing is to check RAM. Some times faulty RAM stops computer to load up and don not display anything.....if the problem persist try to change cmos battery>>> if problem still there then go for supply check>>>>last comes motherboard........
Sep 25, 2009 | HP Pavilion 512n PC Desktop
Dell Precision Workstation 670
Try different memory modules ( RAM ) and see if it is just the RAM.
Also take anything else out you dont need - including dedicated graphics card assuming it has onboard graphics card ( if so then enable the onboard graphics card before taking out the dedicated one )
If its still the same then yes it is the motherboard in which case you need the motherboard replacing.
If you did the diagnostics that they walk you through and they still tell you its the motherboard then it will be the motherboard as there diagnostic software is accurate.
May 06, 2009 | Dell Precision Workstation 670 PC Desktop
L7vmm mb. display went out. Monitor works on
Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
Apr 17, 2009 | Computers & Internet
No display on my asus P4GE-MX mother board
Is there any beep from the motherboard? First thing that you need to check is the RAM. unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Feb 09, 2009 | ASUS P5PL2 Motherboard
Samsung 40 INCH TFT-LCD Cant start up at all .
The noise you are hearing is the power supply attempting to start up. Unfortunately, a component has failed inside the power supply circuit. Most likely it is a capacitor. The good news is that the set should still be under warranty and the repair should not cost you anything. The bad news, is that the service person may not have a replacement power supply board with him/her when he/she arrives. This should be a quick fix as the replacement board is relatively easy to change.
Dan
Feb 04, 2009 | Philips Televison & Video
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
