Maytag PAV2300 Top Load Washer Logo
Posted on Feb 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model # pav2300aww
The tub does not spin in the spin cycle.Actually, it will with nothing in the washer.So it seems everything works. But the belt slips?
  • 1 more comment
  • moetil Feb 24, 2009
    Pump works fine. The motor is mounted so it moves.
    this allows the tension on the belt to vary. Is that correct?
  • moetil Feb 25, 2009
    Yes, it washes the clothes fine. How do you tighten the belt?
    The motor moves in the slots where they are mounted and that
    tightens the belt but I can't get it the stay.
    Thank you so much. I really don't want to have a service call
    if ther is a way I can repair it.
  • cbass902 Mar 03, 2009
    Is the transmission on the Maytag PAV2300 easily repaired? I'm having the same problem. My washer drains, but will not spin. Tub can be manually turned, but not with ease.
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Feb 24, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316666
Points
2771
Check the water pump and make sure it has not locked up-mike
  • 1 more comment
  • Anonymous Feb 24, 2009
    if the water pump is spinning and draining ok then i would say the trans has gotton so weak it can not turn the weight,i you tryed tighting the belt?does it wash cloths at all?mike
  • Anonymous Feb 26, 2009
    I HAD THE SAME PROBLEM MY MAYTAG WASHER WOULD WASH BUT IT WOULD NOT GO INTO SPIN,I WAS TOLD IT WAS THE TRANS.CAN YOU CHANGE YOU RATING PLEASE AS YOU HAVE KNOCKED MY NUMBERS DOWN?THANKS-MIKE
  • Anonymous Mar 02, 2009
    FIXYA RATING WOULD HAVE BENN NICER!!!! MIKE
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 28, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
267
Points
0
It also makes a noise like there is something between the tub and the outer casing.
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Maytag washer model PAV2300AWW does not spin the clothes adequately and vibrates Is it the belt or Snubber?
Might just be a belt which is real easy to replace, no tools needed:
Take that belt off there and check the stiffness of the pump.
These will lock up or get stiff without even leaking.
If that pump seems fine check to see if the main drive pulley is properly releasing the tub in the direction of spin. Their are 2 marks on the pulley, the drum should release in between the two points. if not then the thrust bearing kit needs to be replaced.
I have a pictorial of that and a service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
Won't spin at end of cycle. Maytag top load washing machine
RITS REAL COMMON WITH THAT MODEL FOR THE BEARING TO LOCK UP. TURN THE TUB BY HAND A LITTLE THEN TRY SPIN, IF IT THEN RUNS YOU NEED A BEARING/SEAL KIT.GOOD LUCK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
THE WASHER IS NOT SPINNED THE WATER OUT
Check the belt, the pump, and the thrust washer.The thrust washer wears down and won't release the tub. All these symptoms are easily repaired with minimal tools.
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
