Question about HP DeskJet F4280 All In One Printer InkJet
"E" displayed & won't copy when I try to make a black copy
It seems as though color copies always work, but when i try to copy something with black ink only, the printer won't copy it, and istead just displays "E", and the power button flashes. And the troubleshooting guide doesn't mention what an "E" display means anywhere. What's the deal?
Printer ink door is not shut
Posted on Mar 03, 2009
    Problem Solver:
  • 6 Answers
It's the printer's problem already. it also happened with my epson aio that's why i returned it for f4280.
Posted on Feb 27, 2009
I just put all new ink in my printer and will not print. Unplugged it to re-boot it, still won't work. If i copy something by hand will not print, if i copy something from computer it does not...
be sure that you remove the tape from the cartridges before you insert it in the printer, it has a color pink attach to the tape remove it slowly then insert the cartridge to the printer,
Aug 03, 2011 | Computers & Internet
HOW DO I SET IT BACK TO ENGLISH LANGUAGE? ITS STUCK ON SPANISH.
Setting the front panel language
  1. Press the Menu button four times. When the Maintenance setting appears in the display, press Enter.
  2. Press the Right Arrow key four times and press Enter.
  3. The available languages will flash on the display, but they can also be accessed with the navigation keys. Select the desired language by pressing the Black or Color Start Copy button.
  4. Confirm the selection by pressing Black or Color Start Copy button again or press Cancel to try again.
  5. Press the navigation (ARROW) keys until the correct country appears in the display. Press Black or Color Start Copy button.
  6. Press Black or Color Start Copy button again to confirm the selection or Cancel to try again.
Dec 15, 2009 | HP PSC 750 All-In-One InkJet Printer
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
My printer is printing everything black when using feedtray only
Their should be a Black Copy button and a Color Copy  Button . When wanting to copy a document in color you must choose the color start button.. Good Luck
May 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
My HP PSC 750 printer screen seems to be in German. How do I get an English display? Diana
CLICK HERE for your owners manual in PDF format.
Page 36 of the manual states the following -
HP PSC 700 Series
The following steps help you change the language for your unit.
To do this using the front panel
Press Menu.
2 Press until Maintenance appears, and then press Enter.
3 Press until Set Language and Country appears, and then press Enter.
4 Press until the desired language appears, and then press Start Copy, Black or
Color.
5 Press Start Copy, Black or Color to confirm.
A prompt displays asking to select the country where your HP PSC will be used.
Specifying the country sets your photo sizes applicable for your region.
6 Press until desired country displays, and then press Start Copy, Black or
Color.
7 Press Start Copy, Black or Color to confirm.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 04, 2009 | HP Office Equipment & Supplies
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
We cannot seem to make a copy darker??
i would suggest that 1st you do the auto gradation adjustment full adjust under add function /adjustment cleaning then under additional functions look for one that says printer settings you can adjust black density under that setting
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
Cartridge problem
removed both cartridges and reinstall again, pls make sure that the cartridges are seated correctly
Jul 15, 2008 | Dell 924 All-in-One InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
312 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
