Question about Olympus Camedia C-765 Digital Camera
Digital Zoom and Auto Focus "On" settings are not kept/retained
I set the Digital Zoom and Auto Focus settings/config to "On". after camera is powered off, the settings/config are set to "Off". Can these settings/config be set to "On" permanatley??
    President:
  • 919 Answers
If you shoot in the P mode setting and then go to the Menu and set the option for All Reset to OFF. The camera will retain those settings when powered off. If you are shooting in the AUTO mode the camera will always default back to the factory setting of OFF when the camera is powered off. The All Reset function is not able to be set in the AUTO mode because the camera is already using factory default settings.
Posted on Mar 12, 2009
FUJI F550 HAS PROBLEM WITH FOCUS WITH VIDEO MODE KEEPS HUNTING IN ZOOM BLUR MOST DISTRATING
because the focus is set to infinity it will try to search for something to focus on. try setting it to auto or Manuel focus on what you want to record.
May 05, 2011 | FUJIFILM FinePix F550 EXR Digital Camera
There's something wrong with the focus of my camera. Everytime I take a picture it's blurry and it won't focus unless I zoom in. Is there a way for me to fix it?
ensure finger is not covering auto focus.
ensure camera is not in macro setting. look for icon like a flower this is only for close up shots and will cause bluring if subject is too far away.
check that camera is set in auto focus and not manual focus mode if it has this.
I hope this was helpful.
Jan 24, 2011 | Canon PowerShot SX210 IS Digital Camera
Will not Auto focus is there any thing I can do? I have tried all focus settings and no luck. I can focus a picture by using the Zoom out.
Try the following troubleshooting steps:
1. Initialize the Camera.
MENU-->SETUP-->SETUP1-->Initialize.
2.Power reset the Camera.
Remove the battery of the Camera for atleast 1 minute.
This should resolve the issue.
Jul 20, 2010 | Sony Cyber-shot DSC-N1 Digital Camera
Wont zoom in or out message reads turn the power off and on again can access stored pics but wont take new ones sony cybershot dsc w35
Is this camera only have a digital zoom? If it has an optical zoom as well, you could have a setting that is set to ignore digital zoom and because your lighting conditions, zooming in and out is not currently possible because the aperture can not be opened enough to light you take a picture without being blurry. The auto focus would be taking priority in stopping you from taking a picture.
Just a hunch.
Jul 20, 2008 | Sony Cameras
Lcd window all out of focus..like a cirsus mirror
Usually it is from a smudged lens. Clean the lens and is if that helps. If it is still out of focus check your zoom. Cameras have to types of zoom, optical and digital. Once you reach the max optical zoom the digital zoom kicks in. Digital zoom isn't that great quality because all it is doing is bring the dots in frame closer. If zoom is all the way in and still out of focus check to see what type of setting you are on. Even though you put it on auto there are cameras that have other settings while on auto that you can change the colors and other stuff like b/w, sephia, etc. If all else fails then I would have to say that your lcd is wearing down and needs to be replaced.
Apr 28, 2008 | Cameras
Focussing
Two possible solutions. The camera may be set to Macro. The lens may have failed. If the camera is not set to macro then the lens has to be replaced and the camera reprogrammed.
Sep 11, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
IESP auto focus
iESP is the default auto focus setting for the C-5060 Wide Zoom camera. It uses a contrast detecting system, to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-5060 Wide Zoom, the AF target zone automatically moves the to an area of the image where it finds the optimal contrast.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Difference between the D-460 and the D-450 Zoom digital camera
The D-460 Zoom shares the following features with the D-450 Zoom: •1.3 megapixel resolution - 1280 x 960 pixels •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •2x digital telephoto mode •3x image magnification inspection mode •Sequence mode: Up to 10 images at 2 frames per second intervals (SQ mode only) •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self timer •8 MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings (125, 250, 500) •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-460 Zoom has the following functions and features: •Industry standard icons for button labels and operation menus •Easy to use jog dial and button design allows easy menu navigation •2 compression ratios are now selectable in SQ mode •Selectable Sharpness: Normal or Soft •Selectable Memory Mode Setting: Reset camera settings at power-off or Retain all camera settings •2 Olympus brand CR-3V long life lithium batteries included. Provides 20-30 times the power/life of alkaline batteries
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Olympus Camedia C-765 Digital Camera Logo
159 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
