Question about Kenmore Dryers
How to change the dryer door switch
How to change a Kenmore dryer door switch.
how can remove the door pannel before change the door switch
  • Kenmore Master
  • 19,396 Answers
How to replace ignitor in kenmore dryer model 11073912100
very simple
disconnect the power
remove the pannel usualy you can get to it from the front panel but it may have to be the rear pannel
locate the ignitor
disconnect wires from ignitor
remove it usually only 1 or 2 scews holding it in
intsall is the reverse
if you need more help contact me
Nov 17, 2010 | Kenmore Dryers
No heat
most likely cause is element next would be circut breaker or fuse, or thermo fuse
Sep 20, 2010 | Kenmore 62972 Electric Dryer
How do I gain access to the motor on my Neptune dryer
Open the dryer door.
Remove four screws - two are holding the door and two are holding plastic pieces opposite the door.
With the screws released, the front pannel of the unit will tilt forward and can be removed.
With the front pannel out of the way, two metal retainers found at the top front of the dryer can be released which allows for the top of the unit to be lifted up and removed if desired.
From this point, four more screws found on the front face were removed which allowed the front ducting and front part of the drum to be removed.
The drum was pulled out (work the belt to the rear of the drum while extracting it - optionally, you can release the belt tension by reaching in and removing the belt from the idler)
The motor is accessable.
Professionals may want to pull all the screws from the side pannel and remove it for easier access.
Jan 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do you change the door switch kenmore 500 series dryer
Two metal clips hold the lid down, if the lint trap is on top there will be two screws under it.  Pop the clips with a long skinny flathead, lift the lid up and the door switch should be on top.
Dec 18, 2009 | Kenmore 500 6953 Dryer
Heat and fan are on, but no action with drum
In my expierence with dryers you usually have to take the back pannel off not that one.
Oct 06, 2009 | Kenmore Elite HE4 Electric Dryer
How to remove top panel of kenmore dryer model
Check the video at the following link and see if you find the information helpful in changing the door switch. Sure hope it does and best wishes.
Oct 01, 2009 | Dryers
#1 Unplug the dryer
#2 Use a putty blade under the corners of the Console and flip it back
#3 Remove 3 screws along back of top that were under the console (Might just be 2)
#4 Slide the top forward and remove
You will now have full access to the switch. Disconnect the harness and replace the switch.
#5 Reverse the above proceedure to replace the top
Good Luck,
Jun 08, 2009 | Kenmore 64902 Electric Dryer
Metal against metal scraping. Can't remember how to take the front off the dryer to get to the felt that needs changing. Kenmore front load dryer
Unplug the dryer.
Remove 2 screws under the lint filter door.
Use a putty knife to pop the right and left front corners of the dryer top.
Fold the top to the back.
Inside front right and left corners of the cabinet, remove 2 screws.
:ean the door forward and rmove the door switch wires.
Lift up on the door and remove it.
Reverse above order to re-install it.
Feb 27, 2009 | Kenmore Dryers
Won't spin
the belt is thru the frount.asuming there is noise when you start the dryer and its not turning,yes belt.if wont start at all other things to check first starting with door switch.check with me if need more if wanting in thru frount.pop top and remove frount door pannels.God bless ,tom
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
1,976 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
