Question about Westinghouse LTV-19W3 19 in. LCD Television
Lcd screen white when turned off
My Westinghouse 19in LCD screen is now a white glow when power is off. works fine when on. can anyone help?
  • Anonymous Apr 20, 2009
    Hi same problem, turn off TV and it is bright white. I will try the fix. Thanks
  • 362 Answers
The Backlight is not turning off. Try a hard reset, unplug the tv for several hours. If the reset does not correct the problem you will need the Power Supply replaced. If the unit is still under warranty you will need to return to the merchant or send to manufacturer for repair. If I can assist further please let me know. Lone99star
Posted on Feb 24, 2009
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up ok and works fine.
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 10, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Hello my n71s has been lit white screen and no menu buttons work, I can turn off. I tested on other computers and with various resolutions even in safe mode, help
The screen has white glow and no images means that the LCD controller board (part of the LCD panel) is not getting the 5vdc power feeding it from the logic board through the ribbon cable, it is either the cable came lose or dirty contacts, or failed 5V switching transistor for the LCD controller is bad, or blown fuse on the LCD controller board. See pictures here: http://s807.photobucket.com/home/budm/allalbums
Look at the LCD panel album.
Mar 30, 2010 | Hyundai Electronics ImageQuest N71S 17"...
Why does my westinghouse monitor go white
If the screen is all white glow and no pictures, it means the LCD panel is not getting the 5vdc for the LCD controller board, it can be as simple as the LCD panel connector came loose or you do have the 5vdc supply. You need to open it up and inspect the inside for burnt parts, loose connectors, bad caps, etc. see some pictures here: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | Westinghouse LCM-19v1 Monitor
Monitor stays white, cannot get picture
U might have problem with ur VGA cable. It may be loosely plugged. Plug it tight
Jun 24, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
When power light is green I have no display on the screen
dwanlesso6, Please tell me brand of monitor and if it is LCD/FPD and size 15,17 19 etc. If it is an LCD then it is possible that the DC power supply and or inverter board has failed. Here is short PS101 lesson. All electronic things (Stereo, printer, radio, computer, TV,) all require DC voltage. You get AC Voltage from outlet on wall. the two don't mix. ever!! All the above mentioned things have AC to DC power conversion circuits. They are called power supplys. Only your's and everybody's LCD monitor has two. One makes DC for the monitor logic/digital kinds of stuff, 5.0volts and also makes a
second and higher voltage ( 12v or 15v or 24v) to send to the other power supply which is called an inverter power supply. The inverter PS changes DC into a higher frequency Square Wave AC voltage to power up the Fluorescent Tubes that make your display "bright white" !! Do you own any of those new style light bulbs. You know... the ones that look like small coiled fluorescent tubes and screw into the same socket that previously held the old filiament type of light bulb. Well your dealing with the same technology in your monitor. Just for kicks, you can go to www lcd-monitor-repair. com. Don't pay any attention to the 'advertisement' !!!! just look at the pics of what is inside an LCD/FPD.
The advert just wants you to buy books on LCD/FPD repair.. The best advice I can tell you is try to locate some repair shop that specializes in FPD troubleshooting&repair. Hell, I too am waiting for this 19in GatewayFPD to die. Hope is later.. not sooner, or I'll be in same boat w/LCD/FPD for anchor. Good luck. I'm lmistyrel @ aol north of Chicago been in electronics >3decades
Jan 12, 2009 | Westinghouse L2046NV Monitor
Westinghouse LTV-19W3 19 in. LCD Television Logo
529 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
