Question about Dryers
GE DSXH436V1WW heavy duty large cloths get caught
GE DSXH436V1WW heavy duty large cloths get caught in dryer as it goes around causing rips and brown marks. i have to manually move the drum around to get the clothing out. please help. thank you cindy
  • Anonymous Feb 24, 2009
    Normal 0 MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) }
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}I have a Neptune MDE9700AYW dryer that is 3years old, the drum seems to be off center, tight at the top seal and loose atthe bottom. I am confident this is what is causing the scorch marks on ourcloths as it appears they are pinching in the top of the narrowing seams of thedrum seals.
    The question is… is there an adjustment to the rollers thatcan be made to correct this.
This dryer doesn't have rollers at the front of the drum, it uses a felt rub strip between the drum and the front cover. You'll need to replace the rub strip. It's easy to do but you'll need to get the special high-temp adhesive.
Posted on May 15, 2010
I have the calypso dryer that leaves random brown streaks on our clothes. Any suggestions
Something like this happens when one of the drum supports wears down leaving a gap between the drum & bulkhead. Clothes can get caught-up in this gap & this will cause the brown marks you see on your clothes. Open the dryer door & look around the front & rear perimeter of the drum, if you can see a gap I recommend replacing the drum rollers. If you aren't comfortable making the repair yourself, you can contact a local appliance repair shop or the manufacturer of your Calypso dryer.
Sep 28, 2017 | Dryers
Lint trap doesn't sit right in dryer. It sticks up and clothes ge caught on edges., ripping clothes
Take the lint trap out, and look inside the slot where it goes. You will see a lot of built up lint which will have to be removed so you can slide the trap back down to the bottom.
May 05, 2017 | GE Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Apr 20, 2009 | Dryers
Brown streaks left on clothes
Not having seen this before, but my best guess would be that the piece of clothes is caught in one position and rubbing on the gasket material around the rear of the drum. Is the mark permanent?
Apr 16, 2009 | Whirlpool ET8CHEXSQ Dryer
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryer damaging clothes
Call repairman if you are not mechanically inclined it will be worth the money spent.
Oct 29, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
288 people viewed this question
Top Dryers Experts
