Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAVT634AWW sounds like rocks when agitating
Hi there.
My washing machine sounds like there are rocks in the tub when it is agitating. And the clothes are still quite wet when spin cycle finishes. (I have to run an extra spin cycle to get them dry.) This happens just every 3rd load or so. Belt looks good. What's next? How do I remove the agitator?
Thanks so much!
Jimster
  • 240 Answers
SOURCE: Removing Tub from Maytag Atlantis Washer
I do believe that when you remove the four bolts, it should come out. Sometimes you have to use a little force and shimmy left to right to get it to break loose (no hammers please) especially if you have a lot of scum build-up from soap. They can really be a bear sometimes to remove. Maybe put your foot in the bottom of the tub and hit it on both sides to work it free. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
Posted on Oct 23, 2007
SOURCE: Washing Machine will not agitate
how to take off agitator
Posted on Feb 10, 2008
Cyril J
  • 45 Answers
SOURCE: Maytag Atlantis Washer - MAV6200AWW
bolt has 1/2inch head but dont know the thread size is an orderable part 3 to 5 dollors, may not agitate since agitator not on shft to turn
Posted on May 16, 2008
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
Have a Maytag Atlantis model MAVT634AWW- on all cycles it makes a loud noise like bearings grinding- what could it be and how can I fix it-Thankyou
The first place to look is if something has gotten trapped between the agitator and the drum. Typically coins etc can find there way near or under but not cause a problem. If something has caught it would have to be metal or hard plastic. The agitator can be removed.
Second place is to see if something has become stuck in one of the holes of the drum. It would have to be like a wire/nail that is scraping against the tub held in place by the drum.
Last resort! Being a Maytag you may have a longer then expected warranty on the moving parts. If you do it might be about time to get the Maytag Guy off his b---.
Dec 08, 2015 | Maytag Washing Machines
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Knocking noise during the agitate cycle
you have a brake problem....tub turns while it's washing part?»¿ #21002010 and 35-6918.....will require a specialty tool you can watch videos on you tube just type in maytag atlantis washer
Jan 23, 2011 | Maytag Atlantis MAV6000 Top Load Washer
How do I get the aggitator out of our Maytag Atlantis - it has a steel tub
most of the maytag agitators simply need to be lifted firmly upward and they'll snap off. Watch your face!
Dec 09, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Missing sock in Maytag Atlantis
it's a possibility that the socks have gone under the agitator but unlikely that they have disappeared alltogether. You can remove the agitator to see if they are there. Tha'ts the best I can tell ya Good Luck
Apr 06, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
343 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
