Question about Safari Tiddliwinks Musical Mobile (new)
I have a tiddliwinks product that has come apart. It is the cream "bear blanket" about 14" x 14". The stitching all around it has come apart and my 3 month old son had the loose pieces in his hands. I have used the bear only about 4 times. How/Who do I get in touch with for a refund or replacement (it was a gift)?
  • 350 Answers
Dear diane_bishop,
RE: Safari Tiddliwinks Bear Blanket "Coming Apart After Only About 4 Uses"
If your blanket is a Safari then you may want to try and contact them. They are a big company so I wish you luck @ http://my.safaribooksonline.com/contactus
It appears as though Tiddliwinks is a big item @ Target so you may want to take it there and explain to them how this is not a good blanket for young children if, as you say, it came apart after 4 uses. I'm sure Target Customer Service or Management will be Glad to learn this and will probably pull it from the market and give you something similar for free as a replacement. Either way I would like to hear from you so I can put TARGET on my Good/Bad Customer Service List.
Target Customer Service @ http://www.target.com/E-mail-Phone-Contact-Us-Help/b?ie=UTF8&node=3370571
Target Complaints @ Consumer Affairs & Complaint Button @ http://www.consumeraffairs.com/retail/target_returns.html
jackiaria
Tuesday 02-24-2009 10:18am EST (USA)
Posted on Feb 24, 2009
In crocheting, front post double crochet, which loop do I go thru?
A traditional front post dc is not worked in a loop like most stitches. Instead, it is worked around the "post" of the stitch on the previous row. To work a fpdc, yo, insert your hook into the space before the stitch to be worked around and back through on the other side (the stitch you are working around should be in front of your hook, yo, pull hook back through (there should be 3 loops on your hook), and complete dc as normal.
Dec 30, 2016 | HAND Crocheted Crochet Crossed Stitch...
Can't find blanket stitch
Unable to help without knowing the make & model. FWIW, some machines do not have a blanket stitch.
Sep 25, 2016 | Sewing Machines
Hi I'm new to sewing! Does my singer have a blanket stitch
Your machine is a beginner model with only 8 stitches. Looking at the photo of the machine, it does not appear to have a blanket stitch.
Singer 1507 Sewing Machine
Usually, only more advanced (and expensive) machines with more stitches will have the blanket stitch.
Nov 08, 2015 | Singer 1507
How to do blanket stitch
Usually, your machine would need to have a blanket stitch selection in order to perform a blanket stitch. If your machine does not offer that option, then you are probably out of luck unless it is a highly advanced computerized model that you can create your own stitch designs.
Oct 26, 2015 | Sewing Machines
Can I sew a Blanket stitch with my Bernina 930 Record machine?
Once upon a time, a blanket stitch used to be a long wide zigzag stitch. If you are referring to an electronic stitch version that would look like the inverse of a blind-hem stitch, then no, this is not possible on the 930 record machine.
What is nowadays called a blanket stitch used for quilting applications requires the machine to stop feeding during the stitching cycle to allow for the single stitch to the left and then back again. An electronic step motor machine, common to all newer Bernina machines can do this and or similar functions. That being said, don't be thinking about getting rid of your 930. Better to get one of the newer units for occasional blanket stitching and keep the Swiss made 930. The Bernina 930 is a lifetime machine. Computers machines are not lifetime class machines by virtue of being computers. Electronics are short lived.
SewTechnical Home
Jun 17, 2014 | Bernina Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Foot for quilting
I would use a foot that can do a zig zag stitch or a blanket stitch
Oct 01, 2012 | Janome D'cor Excel 5018
I want to sew two pieces of fleece together and put blanket binding on with a decorative stitch. (Making a baby blanket). Thread breaks or skipping stitches. What needle and thread combination should I...
Take a look at the chart on needle and thread I posted as a tip, but generally, you'll need to use a larger needle, something like a 14 or maybe even a 16, but you shouldn't need heavy-duty thread.
Aug 03, 2010 | Brother NX-400
Ice cream comes out fine at first the mashine doesn't cut off then it seems that the ice cream freeses in the cylinder to the point its to hard to come out
Use slightly warm ingredients or leave the freezer bowl out of the freezer for a few minutes before beginning - this will help if the rim around bowl freezes so fast that it stops the paddle from moving. When working optimally, I found that 3 different Cuisinart ice cream maker models will produce the best ice cream at around 14 to 20 minutes - no more than that. But it varies by your exact model #.
Jun 01, 2009 | Cuisinart DCC-2000
Safari Tiddliwinks  Musical Mobile (new) Logo
347 people viewed this question
Top Safari Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Safari Toy Expert? Answer questions, earn points and help others
