Question about Sony MHC-GX555 Mini Hi-Fi System Shelf System
Sony MHC-5900 Output Problem
Hi!
I have the Sony's MHC-5900 audio Hifi system and last week it started outputting an unclean audio sound (it appears to be "click and pop noise").
I've checked all the cables and connections and everything seems fine. I've realised that if I use the pre-amplifyer in the "Direct" sound mode, this noise doesn't appear in the outputs. However, when I switch to any audio DSP effect (Rock, Pop, ... ), the noise is heard again.
This system is more than 10 years old. May it be some electrolytic capacitors whose time life has expired in the pre-amplifyer? If so, which of them? Can anyone get me the schematics, for at least, the pre-amplifyer?
Regards,
José Oliveira.
bbtoast
  • 319 Answers
SOURCE: No sound from digital out on PS3 using optical cable
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Posted on Jan 06, 2008
SOURCE: Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Posted on Jan 15, 2008
SOURCE: Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
Posted on Jan 30, 2008
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
dunnbiker
  • 8546 Answers
SOURCE: no audio output
Were you playing it very loudly when it died?
The manual is here for reference...
http://www.docs.sony.com/reflib/docget.asp?manualid=11654&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals'
It discusses troubleshooting this problem on page 50.
When you turn the receiver ON does you hear a light click in about 5 seconds? That would be the protection circuitry turning OFF to allow the amplifiers to function. The delay is to allow the circuitry to stabilize before it sends any output to the speakers. If you don't hear a click the unit is Protecting the speakers due to malfunction somewhere.
If no click and no apparent messages try turning the speakers OFF using the Speakers button directly below the Power button (1/0). This will eliminate or point to external shorts as the cause.
Does the unit click after 5 seconds of Power ON with the speakers OFF? Isolate your shorted speaker or wire problem.
Still no sound at the speakers when you turn them ON?
We need to establish if there is any programming flowing through the receiver.
A quick basic check would be to tune an FM station, if you have a tape deck attached, place it in Record or Record/Pause mode so it can display the input signal levels. You should see the record meters fluctuating with the level of the program selected. If you don’t have a tape deck, run an RCA cable pair from the audio output for a tape deck to an analog audio input on your TV. Select that input on the TV and you should hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason.
If there is no audio flowing through the receiver the problem could be a switch in the wrong position, source not selected, muting on or a multitude of other things.
Let me know how this turns out.
Posted on Apr 03, 2009
Hi kindly help me connect led LG Tv output system to a mini hifi MHC-GNZ55D system so as to have powerful sound from TV?
The head unit doesn't have an audio input on it... you could use a tape deck to 1/8" and connect that via 1/8" female to 1/8" female adapter and an 1/8" to stereo cable to connect it to the TV but there will be a level of noise associated with this option due to the components. You could also use an FM transmitter plugged into the 1/8" female adapter.
Apr 11, 2016 | Sony Audio Players & Recorders
Sony MHC-RG660: audio steadily deteriorates on all speakers after powering on.
The problem is in the audio output ic, it is breaking down under load, the solution is have it replaced.
Mar 31, 2012 | Sony MHC-RG660 CD Shelf System
Sony hi fi mhc-55 no sond
The audio output chip is probably shorted, check speaker wires for shorts just in case, if okay! the audio output semiconductor needs to be replaced.
Mar 20, 2012 | Sony Multi-System Mini Hifi Systems / DVD...
I just want to know that how can i connect my sony mhc rv777d to my pc
Input to the the PC or OUTPUT from it? It matters.
To use the Sony as the speakers for the PC, treat the PC as you would any other audio source. You can use the headphone out or the green speaker out or any available digital output if you have one. Just make sure you adjust your PC's sound controls to enable them and turn up the volume.
Apr 08, 2011 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
My sony mhc-rv777d is not working when i on my sony within 4or 5 sec it off automatically so i need a solution
MHC-RV777D shuts off itself because of protection mode that is activated to avoid further damage due to defective amplifier output IC in unit.
You need to check/ replace output amplifier IC to solve this issue, if you are not familiar with electronics stuff repair then local repair shop will do this job for you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 03, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
Game video input enabling
Dear krismedia
You should first confirm that Audio/Video output cable from the hifi is connected to the TV , then you should connect the game console to the input section in ur hifi system. And finally see if the TV is in AV mode and also see if the HIFI is detecting in the input mode.
Dec 12, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Sony MHC-RV888D Tape Recording to LAPTOP - How to connect?
you have to connect the S-VIDEO output of the device to your laptop via s-video - usb cable , if they do not have a cable like that than you might as well use an adapter from s-video to usb, if u have your hands on one.
the second method is to hook up a audio recorder from the speaker output, and use a volume controller witch steps down the speaker output so you can plug the cable directly to your laptop microfone output..
good luck!
Apr 11, 2017 | Sony MHC-RV888D Shelf System
Sony MHC-GX555 Mini Hi-Fi System Shelf System Logo
127 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
