Question about Home
I have an Eago AM128JDCLZ Deluxe Whirlpool Bathtub and cannot for the life of me get any hot water when filling it up. It has a thermostat control dial but no matter which way I turn it the water temperature stays cold. I have a manual but there are no step-by-step on how to fill it.
  • Rod Kidman
    Rod Kidman May 11, 2010
    What do you mean you can't get any hot water? is there a hot water heater?
    If you are refering to an inline bathtub heater, they will NOT heat the water from cold. They will ONLY maintain the temperature of the water of what is put in the tub. You will NOT ever feel hot water coming out of the jets like you would a return fitting in a swimming pool.
Hi i can help you if you call me at my showroom on 01623 661111 aks for wayne
Posted on Mar 04, 2009
  • 125 Answers
Turn the thermostat all the way to the right to its highest setting and leave it there. it will only maintain the temperature of the water you put in the tub. so if you start with 98 F water it will not heat it up to hot water. Bathtub heaters ONLY maintain the temperature of the water.
Posted on Feb 24, 2009
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
Hose does not dispense cleaning solution, and the cleaner solution will immediately go down to the dirty water tank. It can suction, though. Any tips?
sounds to me as if you have calcium deposits from hard water.
Take your cleaner solution reservoir and fill it with Vinegar and Hot water. Place your machine in a dry bathtub and run it until the tank is empty. Do this a couple times. When it works properly run some clear water through.
Mar 19, 2013 | Kenmore 85930 PowerSpin Deluxe Upright...
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
I have a Eago bathtub and most of the times I
Then i would defnetly recogmend replacing the thermostat inside your mixer with new one
Jul 11, 2010 | Home
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Only used my Royal whirlpool bathtub about three times
My jetted tub will not work, and it used to work just fine. Nothing happens when i push the button to turn it on. Could this be a switch problem? Also do not hear the motor doing anything when button is pushed. Dou you think I just need to get a new pump??
Dec 30, 2009 | Home
Bathtubs Safety Question?
Yes. They are every bit as safe as your standard bathtub or shower. Unlike outdoor spas or hot tubs (which are similar to swimming pools), your indoor whirlpool bathtub is emptied after each use. There are no chemicals or stored water involved.
Aug 27, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Home Logo
515 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
