Question about ASUS Eee PC 1000 Notebook
Asus 1000 freezes after 2g ram upgrade
After installing a 2g ram my brand new asus 1000 40g freezes after boot up. I have to power down and re-boot. It does it 2 to 5 times and then runs great. Any suggestions?
  • Anonymous Apr 15, 2009
    I also upgraded the memory to 2gb and then had this problem. I am not sure if it is reelated to a defective memory, or the computer or the wireless. It is probably related to the power saving mode; but I am not sure.
Go into bios and make sure mem is set to auto find ,might help
Posted on Mar 04, 2009
Asus F3Q will not turn on
The connections at pins and holes could just be dirty or possibly the solder is broken loose inside the recepticle in the Asus.Latter is most likely.If you're into fixing it,and the soldered connections in receptical are bad,luck to ya friend.Would but be a good unit to upgrade to Windows 8 with an Intel processor and 4Gb RAM,even a 500 GB hard drive.Hmm,may a swell just buy a NEW ONE.I'm kidding.I personally like working on computers.I've kept this 2008 Toshiba running since August 08.Done probably 10 or 12 re-formats,3 different hard drives,went 4GB RAM and back to 2 GB and made no difference in speed.I'm about to retire this one this week and go to the Asus that I found on sale at Staples for $279,with all the fine bells and whistles I spoke of earlier.Have a food day.Regards,Rigger.
Apr 15, 2014 | ASUS F3Q-AP003E T3200/2.0/320/2G/15/XPP PC...
Asus eee pc 1005hab will turn on but will not boot up. cannot get into bios vis f2, esc. just a frozen screen that says asus eee pc press f2 for bios. I have disconnected the battery many times, will not...
I have an Asus Eee pc 2g surf. I inadvertently installed a bios 2008 upgrade and cannot provide a password and cannot get beyond this page. Assus techs cannot provide it without an invoice and I have none as it was a gift. Any solution? I have taken out the battery, pressed f2, shift f10 ( which gets me to a screen "Atheos Boot Agent Configuration Agent" but not sure how this will help)
Jan 19, 2011 | ASUS Eee PC 2G Surf Notebook
How much can you upgrade memory (RAM) in a asus p4vp-mx motherboard. There are 2 slots with 256K each (128 pin, I think)
The Asus P4VP_MX has two slots for DDR2 SDRAM and supports a maximum 2G of memory, 1G per slot.
Aug 06, 2010 | ASUS P4VP-MX Motherboard
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
My asus eee 900 pc with 512mb of ram, i upgraded to 2gb of ram, and it restarted fine, now with either ram chip in it it will start to boot up, but the screen stays blank and it attempts to start up with a...
request you to check speed of 2 gb ram with old 512 gb, if u r using 2 strrips of 1-1 gb then first remove both and resinstall old 512 again, and checked, again install both 2 gb ram and check. if after installation of 2 gb ram laptop is not restarting the problem is only with speed of ram. u may need to install ram with proper matching speed
May 26, 2009 | ASUS Eee PC 900 PC Notebook
I changed my1G ram in my asus 900ah to a 2g CrucialDDR2
As reported on the EeeUser forum, the EeePC 900 is somewhat picky with RAM upgrades. If the RAM chip is not exactly spec’d like the stock RAM module, then the computer would be prone to freezing, especially when switching between battery and mains power.
Also, note that the RAM module that came with the EeePC 900 is an AData PC2-3200 (running at 400 MHz) with part number DOGC1A08342. I find it strange that the chip is a 400 MHz one. Even the original 512MB chip that came with my EeePC 701 was a 667 MHz one!
This means if you plan to upgrade your 900’s RAM, better make sure the module is compatible!
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 20, 2009 | ASUS Eee PC 900HA Notebook
Display driver problem
Hi there ;
hey can u boot into the safe mode and go to the system restore from there and restore it just before the time that it messed up if not please let me know there is still things that we can do
best regards mike
Mar 07, 2009 | ASUS Computers & Internet
RAM MEMORY WONT INSTALL/DOES NOT WORK
It sounds like the RAM you ordered is defective.
I would put the your old ram in and verify that the system boots and operates properly. If it does, then I would send the RAM in for replacement.
I hope this helps,
Thanks for using FixYa,
Eric
Jan 22, 2009 | ASUS P5VD2-MX SE Motherboard
Ram replacement
Motherboard might not be able to recognize ram. Try old ram first. Depending on the beep, they typically mean that there is no/bad ram or no/bad video card.
Apr 23, 2008 | ASUS A7V8X-MX SE Motherboard
ASUS Eee PC 1000 Notebook Logo
401 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
