Question about E-Machines eMachines Desktop PC
I have a e-machines,when I pushed in the starter button it stayed in and cap came off. Now I can't shut it off. Who do i call to fix. I shut my computer when not in use. Please help, Thank you
    Novelist:
  • 121 Answers
My name is ArmyMason this isn't a big issue and it can be fixed. If you have a screw driver open the case by removing the screws in the back. if the computer is running tell it to shut down if it wants to boot back up pull the plug. Now with the case off, the front panel has clips on the inside of the case all you have to do is pop off the front panel. Pop out the button, the switch to turn on the computer should be attached to the case where the button is suppose to line up with on the panel. If the button is broken just leave it out put the front panel back on and put the case back together. Now see if you can turn on the computer without the button. If you cant reach it try poking something small in there to push the button. If you want to replace the button, I would check ebay or craigslist for a replacement case, they should be cheap. Also you dont nessessary need the exact model as long as they look the same it should fit.
Hope this helps,
ArmyMason
Posted on Feb 24, 2009
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
Power does not stay on.
check and replace caps in the power supply as they maybe leaking causing the voltages thought the unit to be unstable.
Apr 15, 2008 | Hitachi DV-P745U DVD Player
I have a sensory dryer lg less than 2 yrs old dle2301r and today it just shut off will not turn back on there is power the light still comes on help please
id look at the starter cap..........silver can next to the motor.......
machine can be tested by removing the lid...
power on....then.....very.. very carfully push the drum..
if it bursts into life...then you need a new cap......
be careful...........good luck........
cheers
Apr 06, 2011 | Dryers
My high beam and low beams wont work but the tiny lights right next to them and all other electrical stuff seems fine....wat could my problem be?
Some Yamahas are designed to shut off the headlight while cranking starter to conserve battery power.
I'm not sure your R1 was built that way...but other models have the same problem.......
The starter button has a set of contacts for headlight, and a set of contacts for starter circuit.....as you push in the button, the headlight contacts open first...then as you push further the starter circuit contacts close to crank the starter. If the button does not fully release after starting the headlight stays off. So try WD40 around the button edges and work the button in and out several times with key off....then recheck headlight operation with key on.
Mar 05, 2011 | 2005 Yamaha YZF-R1
No action at all from starter motor, not even a click when you press the button.
Follow the positive battery cable to the starter solenoid. Unplug the two small wires going to the starter solenoid and push the starter button . With a voltage meter on the wires from the harness you should have continuity.Reconnect the wires. Push the starter button, if you hear a click from the solenoid the button is good. Now, jump the two cable posts on the starter solenoid. If the starter works you have a bad solenoid. If you push the starter button and tap on the starter with a plastic hammer and the starter works, you need new starter brushes. If anything else in the starter is keeping it from working (shorted or worn armature,corrosion, bad end cap, etc.) you need a new starter , the starter parts are not available from the manufacturer.
Sep 29, 2010 | 1991 Yamaha XJ 600
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Saeco royal espresso machine
Ventilate just means that the system has senced a lack of water flow and shut down. Push the button to have water come out the wand and that should reprime the unit. If however no water comes out and the message stays on then you have another problem If water does come out but the message stays on then you have another problem. If in either of these cases you should google "saeco repair" and send it to an authorized saeco repair center to have it fixed.
Aug 26, 2007 | Saeco Royal Professional Espresso Machine
E-Machines eMachines Desktop PC Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
