Question about Maytag Dependable Care LAT9706
Brake Squeal on Maytag MAV5000 AWW
The brake on my Maytag MAV5000AWW has a terrible squeal at the end of the spin cycle. Can this be lubricated, with what, and is the brake accessible by taking the front panel off?
Thanks
Joe
  • 5,911 Answers
Here's the same advice I gave another person with a similar problem to yours. The squealing can be caused by the brakes, or a worn snubber. It's usually a combination of BOTH. Since you may have to take the to disassemble the unit to repair, it only makes sense to replace the snubber as well. The part costs less than $10 in most cases.
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber by using corn starch. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
NOTE: You cannot access the brake pad or snubber by simply removing the front of the washer. You can SEE them, but you won't have full access until you disassemble the washer as outlined in the link I provided.
Posted on Feb 28, 2009
My Maytag washer mod# MAV5000AWW drains but does nt spin. It was making a grinding sound the day before. I removed the back panel and found that the trans. was hot. Im a handy person but never worked on a washing machine. Im wondering if i may be able to fix it and learn something or get a new one and see what made the old one tick.
Posted on Aug 09, 2009
1982 Maytag Washer model LA210, drive belt squeal after spin.
That is usually normal. That is the sound of the brake applying against the tub to stop it. Smaller loads will be longer because the tub is moving faster and it takes longer to slow down.
May 06, 2012 | Maytag Washing Machines
2002 dodge durango 2wd. brakes squeal when braking. i have had rotors and pads replaced.
There are 3 to 4 different compositions of brake pads--some are softer--others are ceramic or metallic---probably you have gotten metallic---which do have a history of squealing much of the time. therefore, check to see if that is what you purchased--if so--there is no mechanical problem. However--a tip--especially in colder, salt-using, (on streets)climates. Lubricate the brake rotor sliders with grease twice a year so they don't stick.
Feb 18, 2011 | 2002 Dodge Durango
Will I need a caliper reset tool kit to change the brakes on my 2007 toyota sienna or will a standard c-clamp do the job? And since it is an ABS system, I assume that brakes must be bled, correct?
Brake Pads Removal & Installation Front To Remove:
  1. Remove the front wheels. Front brake caliper (exploded view) toyota-09-00-5838.gif
  2. Loosen the caliper bleeder.
  3. Hold the slide pin; remove the 2 mounting bolts and remove the brake caliper from the support.
  4. Support the caliper.
  5. Open the brake bleeder. Press the caliper piston into the bore.
  6. Close the bleeder after the piston has reached the bottom of the caliper bore.
  7. Remove the brake pads, support plates, wear indicators and anti squeal shims.
  8. Remove the slide pins and bushings from the caliper support.
To Install:
  1. Lubricate the slide pins and bushings with brake grease.
  2. Install the bushing on the slide pin.
  3. Install the slide pin on the caliper support.
  4. Install the brake pad support plates on the caliper supports.
  5. Lubricate the anti squeal shims with brake grease.
  6. Install the anti squeal shims on the brake pads.
  7. Install the pad wear indicator facing upward and install the pads on the caliper support.
  8. Install the caliper on the support.
  9. Install the 2 mounting bolts, hold the slide pins and tighten 25 ft-lb (34 Nm).
  10. Fill the reservoir and bleed the brakes.
  11. Install the front wheels.
Rear To Remove:
  1. Remove the rear wheels.
  2. Loosen the caliper bleeder. Rear brake caliper (exploded view) toyota-09-00-5842.gif
  3. Hold the slide pin; remove the 2 mounting bolts and rear brake caliper assembly from the support.
  7. Remove the brake pads, support plates, and anti squeal shims.
  8. Remove the slide pins from the caliper support.
To Install:
  1. Lubricate the slide pins with brake grease.
  2. Install the slide pin on the caliper support.
  3. Install the brake pad support plates on the caliper supports.
  4. Lubricate the anti squeal shims with brake grease.
  5. Install the anti squeal shims on the brake pads.
  6. Install the rear pads on the caliper support.
  7. Install the rear caliper on the support.
  8. Install the 2 mounting bolts, hold the slide pins and tighten 25 ft-lb (34 Nm).
  9. Fill the reservoir and bleed the brakes.
  10. Install the front wheels.
Sep 18, 2010 | 2007 Toyota Sienna
Washer squeals at end of spin cycle
The manufacturer recommends you tilt back the washer and spray some penetrating oil into and around the brake package to stop the squeal.
Jan 18, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Van brakes squeal/whistle even when stopped
Sounds to me like a dry, loose or worn serpentine belt. With the motor idling, lightly spray the serpentine belt as it's spinning with WD-40 or other oil based lubricant (Don't spray near the alternator). If this doesn't work, turn the mortor off and check the tension and for cracks or worn spots. The brakes will not squeal when you are completely still.
Jun 11, 2009 | 1999 Chrysler Town & Country
Washer squeals during wash & rinse cycles.
It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
May 29, 2009 | Maytag PAV2300 Top Load Washer
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Load squeal
if you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Older model Maytag washer, it makes a lod squeal noise at end of spin cycle
its the brake dont worry it wont heart athing but you can put some greese on it
Nov 28, 2008 | Maytag Performa PAV2200
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
1,364 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
