Question about Singer Computers & Internet
SINGER LCD TV ASM TUNNING AFTER THREE SECOND AND NOT CONTORABLE
SINGER LCD PRODUCT # SCT21A71PTC , WHEN STARTED AUTO SERCHING OPTION AUTOMATICALLY SATART EVERY THREE SECOND LATER. HOW CAN I REMOVE THIS PROBLEM FRO MY TV
SOURCE: LCD Tv turns off automatically within few seconds
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Posted on Mar 11, 2008
SOURCE: Windows XP Service Pack 2 shows asms missing
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Posted on Jun 06, 2009
SOURCE: unable to re tune the tv
http://www.fixya.com/support/t933113-sony_trinitron_tv_model_kd_28dl10u
Posted on Sep 30, 2009
  • 159 Answers
SOURCE: My Daytek LCD TV has audio but no picture,keeps
Hi, Sounds to me like you are almost assuredly encountering a no signal problem. This would account for the auto tuning not doing anything. I would suggest a newer antenna. Local department stores carry a variety of " DIGITAL T.V. " antennas. And as far as the no audio part I have actually "seen " that problem on my own t.v. ( a portable ). When the tuner does manage to grab a signal if it becomes too weak the picture may freeze or go all diagonal or just disappear altogether leaving just the sound. I hope this helps and thanks for choosing FixYa, Good luck ,Prodzilla
Posted on Apr 14, 2011
AJIN G
  • 6694 Answers
SOURCE: I have TCL TV set.
Hello
The mamory IC inside the circuit of your tCL tv is faulty. Memory IC is one which transfers data to main system IC when we switch the set ON each time. Now it transfers the data to the system IC ofcourse, but not memorize the [LPM]; last position memory. This IC can be located very nearto the main system IC; will have 8 solder terminals. It can be easly unsodered out and resodered in. Its number is most important. Keep a keen look on its number and buy an exact replacemnt. It will be very cheap to buy, and can be had from most of the electronic spare part shops at your town. OK.
Posted on Jun 29, 2011
My television problem is the channel is keep on changing automatically non stop. How can i go to channel tunning? This problem was happened just 11 months when i bought it and i send it to the Sharp...
Hello, there are three options for such failure, the first and simplest is to try to get the remote control out of the room while the TV is off when it is in stand bye. A second possibility is the micro switches in front of the TV, you can verify that they cause failure by disconnecting the cable that connects them to the main board. If the problem stops, you will need to replace all the front switches. And now the last option, however the more expensive one, that there is a malfunction of the micro-processor circuit, from which comes the command to turn on the TV. let me know if that was helpful! Please come back to me, if you have any questions or if you need further guidance
Mar 06, 2011 | Sharp Televison & Video
Automatic tuning from new only brings up RTE1 & 2. How do we get the TV to tune in all the other stations. We are in Mayo and it seems that the Freeview is not working. Would appreciate your help,...
hi
press menu key on remot cantrol and selact your contry tuner system
EXP: USA / CANADA /SOUTH AFRICA / UK ./CHINA / INDIA ..and after selact contry. set chenal Auto serch and see all chenal is perfactly set
Oct 30, 2009 | Hitachi L32H01 32 in. HD-Ready LCD TV
Tuning without a remote
pls use panel menu key prees and select tuing menu and see display in ASM [auto serch memory] select ASM befor ch.no set is "0" and select ASM .
use panel ch+ ch- is up and down select key is v+ and menu key is menu next page
Oct 08, 2009 | Televison & Video
Not tuning
videocon 20 tv asm serch fine lock help
Oct 06, 2009 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
How do i get the cable to show on my tv it says no signal
do auto tunning,press menu & select tunning proses
Jul 09, 2009 | JVC LT42P789 42 in. LCD TV
When the tv on then auto tunning start
same of the tact switch are defictive so change all the switches with a new one or else try to fix that switch
Aug 23, 2008 | Sanyo DS20930 20" TV
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Monitor turns off
sir\maam i think there something wrong with the power supply of your laptop,,tv kindly check the power supply section,,,hope to help you thnkzz??
Jan 29, 2008 | CTX S762A 17" LCD Monitor
Poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Dec 27, 2007 | Televison & Video
Goodmans w282ns silver
in your remote control there will be one button calles ASM or auto search mode you press it (or auto) tv will tune one by one channel automatically & it will stop. now from prog. button you can up &down channals. from vol +&- vol up& down. good luck.
Sep 19, 2007 | Goodmans 289NS 14" TV
Computers & Internet Logo
340 people viewed this question
Top Singer Computers & Internet Experts
NOEL
NOEL
Are you a Singer Computer and Internet Expert? Answer questions, earn points and help others
