Picture Having a problem with the picture. When you turn on the tv there will be a full screen picture or half screen picture briefly. Then it shrinks to a line running in the middle. This keeps going back and forth. However, there has been times when you turn it on and it works some-what normal with just a line at the very top. There is sound. Any thoughts? I don't know if it is worth getting it fixed.
    Problem Solver:
  • 7 Answers
It sounds like a loose solder contact in the vertical circuit.
maybe on the vertical ic or some caps in the area.
Posted on Feb 24, 2009
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
When i turn on the tv, the bottom half of the screen is black. after a few minutes, i have a full picture.
set uses two boards to drive the picture, one for top and other for bottom half---sounds like one is bad in this set.
Mar 30, 2012 | LG Televison & Video
Sub picture of my sanyo lcd-32k30 in pip/pop are not clear
my sanyo lcd 32k30 have a problem when i turn on half on the screen the picture is ok and the half is black after a few seconds the picture is full what is the problem? can you help me of this trouble of my sanyo lcd 32k30 thank you
Jul 19, 2011 | Sanyo DP19649 LCD TV
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
Vizio sp42a
your tv is having a problem of more than one component .to get rid of the problem u should rectify your vif horizontal and vertical sections
Sep 24, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Nov 18, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
