Question about Maytag MAV6200 Top Load Washer
Grit Deposits Getting what appears to be a rubber-based grit in the washer. It's marking up the clothes. Not sure if there's some form of seal that's deteriorated or something is occuring in some other part (like maybe the pump. No indication of a lead. The input filters both look clean. I'd bought new hoses, but after looking at the filters, I'm not surprised that wasn't the problem.
  • Tim Strickland Aug 02, 2007
    Okay. I broke out a wrench. Under the agitator there's a plastic spoke-type gear over a metal bushing with a rubber insert. That's all pretty much gone. And that, maybe in combo with whatever the potting-looking stuff us at the base of the inner basket (a cup about 2" in diameter with the inner basket bolts just outside that diameter) look to be the culpret. Next, I'm on a parts search.
  • Tim Strickland Aug 25, 2007
    Thanks. I've learned that this is the older Seal Nut which is no longer available. Maytag changed this seal as part of an entire seal kit; the new kit requires a higher-torque transmission. So to replace this little part, I need to replace the entire transmission and associated seal kit. Not a cost effective solution since the washer cost $400 and the parts alone cost over $200 (plus some special tools). All this because they no longer make the original seal nut. Since the seal nut is bad, I'm running the washer as long as it will go before I have to replace the emtire unit (for about the price I'd be paying to replace the seal).
  • 625 Answers
Best bet is to go to repairclinic dot com for parts.
Posted on Aug 23, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Aug 26, 2007
    I just looked at the parts select appliance site and they list the tub seal item 26 27
Cistern
The arm controls the Flush Valve. Inside the flush valve is a black rubber "seal" that closes the end of the fill pipe and stops the water. If a piece of sand, grit, or small rock gets imbedded in the seal it will allow water to pass through even when the tank is full. Either you take apart the flush valve and remove the grit, or you replace the whole valve. Sometimes even when the grit is removed the rubber seal is damaged and must be replaced. A new valve, and some of these replacement seals can be purchased at a good hardware or plumbing supply store. Use the valve handle, below the tank, on the pipe that comes through the wall, to turn off the water before replacing the seal or valve.
May 26, 2013 | Home
Black marks appearing on towels. Look like marker, smudged.
hi.
it could be the seal on the front of the drum starting to break down.
clean the seal at the front of the drum that seals the door. then rub a white cloth/towel around the seal
if there are any marks left by the seal then the rubber compouds are starting to break down and the seal needs to be replaced.
please feel free to ask for detailed instructions on changing this seal if you need them
Apr 13, 2011 | Frigidaire GLTF1670A Front Load Washer
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
Kenmore clothes washing machine water drip
Replace your washer mixing valve. This is the fill valve for your washer. Also install the newer safer stainless steel fill hoses and install fine mesh coned hose screen washers in the end that connects to your house valves. This will prevent the grit or corrosion from getting into your new washer valve and causing another repair. Good Luck, Appliance Specialists
Dec 20, 2009 | Washing Machines
When we run the wash, black marks appear on some clothes. No pens or foreign objects are in the washer.
It can either be the rubber seal around the washer door or the bearings (normally sealed) for the tub may be leaking and getting grease into the tub. I think usually the bearing grease is brown in color. For some reason, as the rubber seals deteriorate, they tend to mark up clothes. At least that has been my experience. You may try wiping them down with some sort of cleaner (fantastic, greased lightening, etc) and see if that helps any.
Aug 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Black streaks on my laundry
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Jul 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown lines on clothes (whites and lights) from the dryer
you need the top seal replaced it is wore and clothes are getting stuck in the front seal...
if you are handy you can do it yourself...
Jun 17, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Clothes smell of old dirty water, after washing
this will solve your problems
Affresh™ Washer Cleaning Kit Affresh™ Washer Cleaning Kit contains 3 Power Puck tablets and 6 Grit Grabber cloths. The tablets remove and prevents odor-causing residue that can occur in all brands of HE washers. Affresh™ cleaner is a formulated, slow-dissolve, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean. Simply place one tablet in the wash basket (without clothes) and run a Normal Cycle (hot option) or Clean Washer Cycle. The Grit Grabber™ premoistened cloths have been formulated to penetrate, dissolve and remove odor-causing residue from the rubber door seal. Now consumers can clean where they can't reach with the Power Puck™ tablets and where they can with the Grit Grabber™ cloth. Affresh™ brand is environmentally friendly, safe on septic tanks, and safe for all washer components. Package includes three tablets. Part #W10194073 $10.99
Please remember to leave a solved rating!
Dec 07, 2008 | Whirlpool Washing Machines
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana washer "goo" on clothes?
Ann, these Amana's are the mother of all washers to change out the seal and bearings. It's possible you just have a lot of gunk built up on the inside of the basket from years of washing. I would not put a cent into it. You are better off getting a new direct drive washer. Catriver...post back.
Oct 08, 2006 | Amana NAV3335A Top Load Washer
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
