Question about Everex NM3500 Laptop
I need cpl30a5a.inf file - Everex NM3500 Laptop
Brother 2200 driver
Most of the drivers located on the brother website are in the form of an Executable setup file which goes through and sets up your printer. The INF files are there just need to unzip the file and find them in the directories if you want to set up the printer manually.
Apr 02, 2014 | Brother HL Office Equipment & Supplies
Whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
I have Compeq C7oo lappop,Need sound card,Please help me..
I assume that you have installed Windows XP on your system. Follow the below mentioned steps to install the Audio Drivers.
Before installing audio drivers, you have to install Microsoft UAA Bus Driver for High Definition
First you have to install the Microsoft UAA package. Click here OR here to download UAA
Then download Compaq C700 Audio Drivers and install them. I hope this would install the drivers. Else, go to the Device Manager and update the sound drivers from the folder named
sp33867 located at C:
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 03, 2011 | Computers & Internet
Our 2002 Gateway computer will not recognize a USB
Go to the following website listed below and download the file you need. It needs to be placed in the C:Windowsinf directory (not in any folder).
http://www.infdump.com/download-inf-file
Nov 15, 2009 | Western Digital WD Passport 250GB Portable...
I have a toshiba satellite a105-s4114. Did a fresh install and can't get the SD card reader to show up. I have gone to the Toshiba website and installed what should be the correct drivers. For the Texas...
INF error usually occurs if the inf file is missing or the auto run .inf extension file is missing. INF is used to load the auto run of the application that made it possible to be used to any specified application that serves its purpose. So therefore your SD card reader won't show up due to the face that its INF file that is responsible in loading it application is missing. So i recommend that you have to reinstall completely the driver of SD Card reader in order to be able to use the application.
Thanks
Aug 06, 2009 | Toshiba Satellite A105 Notebook
Plz give me compaq presario c700 audio driver
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Do not click on the link. Please copy the link and paste the link at the
address bar of the browser. Next hit the enter key.
k
Installing this driver may result in an error. But continue with the
following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant
High
defination audio entry and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from
the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp35940 folder and the double click the
(WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
Audio come from headphone as well as laptop
k
High
install"
the
list.
May 12, 2009 | HP Compaq Presario C700T
No audio
k
High
install"
the
list.
(WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file,
May 11, 2009 | HP Compaq Presario C700T
I own a compaq c734tu notebook. i am unable to upload sound drivers. i don get ne sound in my laptop. i have tried with all possible updated drivers which i cud use bt still its nt working. i have windows...
Hi Shree.
I will provide you a driver which has worked for lots of people. Try this driver and let me know.
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.    Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:    ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
  After installing the UAA driver reboot the notebook and install the audio driver from the following link:
Conexant CX20549-12 High Definition Audio driver:    ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.    1. Click on Start and select Run. Now type devmgmt.msc and press enter.  2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS" or Conexant High defination audio entry and click Update driver.  3. Select "Not at this time", click on next and Select "Install from a list or specific location"  4. Click Next. Then select "Don't search, I will choose the driver to install"  5. Click Next and then select "Sound, video and game controller" from the list.  6. Click Next and then click Have Disk.  7. Click Browse C:\swsetup\sp35940 folder and the double click the (WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file, click open and Continue with the onscreen instructions.
Oct 03, 2008 | Compaq Computers & Internet
Drivers for presario c734tu laptop for windows xp
Hello chandra,
2. Click on + sign nest to the Sound, video & game controllers and right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant High defination audio entry and click Update driver.
Sep 07, 2008 | Everex NM3500 Laptop
Everex NM3500 Laptop Logo
211 people viewed this question
Top Everex Computers & Internet Experts
Brian Sullivan
Brian Sullivan
IT Solution
IT Solution
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
