Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Dishwasher hotpoint dc23 dial sticking water not hot
No voltage at heater element, cold water, and programmer dial sticking.not moving at start of wash and rinse cycles is it programmer or something else
gittos73
  • 244 Answers
SOURCE: hotpoint ultima wma62s
it possible isnt the heater elemant it will more then likely be your thermostats which are close to your heater element change both i always have so i dont need to go back to a customers house to change the other at a later date m8
Posted on Feb 24, 2008
ghappliances
  • 126 Answers
SOURCE: hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • 104 Answers
SOURCE: hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
Posted on Nov 01, 2008
  • 100 Answers
SOURCE: Dishwasher Hotpoint 7885 Aquarius Ultra Plus
sounds like the heater for sure. engineer job.
Posted on Jan 27, 2009
SOURCE: My Hotpoint WMA58 washing machine is not heating
We had this problem & called our repair man in. We had accidentally knocked the 'Variable Temperature' dial down too low. It should ALWAYS be set to max (95). The programmer will still sort out the correct temperatures for the different programmes, such as cold wash, but setting that to whatever temperature means that that is the max it will ever reach, Since then, we have not had that problem again.
Posted on Apr 04, 2009
Have a Hotpoint dishwasher DWF33. Supplied with cold water supply from mains. My problem is that water is not heating during operation. Regards, Stephen.
Always supply hot water to the dishwasher...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 10, 2011 | Hotpoint Dishwashers
Water may stay hot for 5 minutes then gets cold. water heater often blows breaker or pop out switch.
I suggest taking 30 minutes and testing water heater parts.
Right away we know 2 things:
-Electricity to heater is good.
-Upper element is receiving power because you have some hot water. If upper element was burned out, you would have no hot water.
That leaves 5 suspects:
Upper thermostat.
Lower thermostat.
Loose or shorted wire.
Upper element shorted to ground near center of element.
Lower element shorted or damaged in some manner.
Buy $10 milti-meter from Home Center or hardware
When test calls for testing voltage, rotate multimeter dial to 240-250-277 VAC.
When test calls for testing elements or continuity, rotate multimeter dial to Ohms.
Take 30 minutes and go down page.
Test will identify problem(s) and show how to fix it yourself.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone while you work on water heater.
Jan 01, 2011 | RELIANCE ELECTRIC WATER HEATER
Water is cold
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Jun 08, 2010 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Water too hot and goes cold within minutes (electric)
The heating element must be shot. There is an adj there, but it is a tiny dial, and I'm not sure about the 30 gal, but most heaters have 2 elements. If yours starts out too hot then runs out, Blame the element, or check the breaker with a meter to make sure you have voltage to both legs of the 220 volt line. Sometimes one will quit there, and leave you half power. Check it out.
May 22, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My Hotpoint WMA58 washing machine is not heating the water so the cloths are only getting washed in cold water. Will this be the heater element that has gone? If so how do you change it.
Apr 02, 2009 | Hotpoint WMA58 Front Load Washer
I have a Bosch SHV55M03GB dishwasher which does not heat the water. The programme cycle also sticks at the last minute. Any ideas, heater element or control panel? Thanks.
If cycle proceed normally after waiting for a while, then the control is probably OK. It stands by a while because it does not read correct temperature before proceeding.
If the appliance is connected to both hot and cold water, open more the hot water faucet.
If the water is not heating at all, check heating element for continuity, using a tester.
If water is heating regularly, but cycle is still slow, check thermic sensor.
Here are more suggestions from Repairclinic:
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
If you need replacement parts or exploded views you find them here.
Oct 10, 2008 | Dishwashers
MATSUI DISHWASHER MS160SL. IT STICKS HALFWAY THROUGH THE WASH PROGRAMME. IT IS NOT GETTING HOT. DONT KNOW IF ONE PROBLEM IS CAUSING THE OTHER IE IF THE ELEMENT NOT HEATING IS CAUSING THE PROGRAMME NOT TO...
I have the same problem and have found that it is caused by as you suspected a burned out heater element. they can be purchased on the web for £15.95 at partmaster .co.uk
Sep 23, 2008 | Dishwashers
Hotpoint bwm129 gets stuck mid cycle and dial does not move round
Sep 15, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
